Home > Help Needed / General Tech Chat > Timing cover mod for Duplex Chain
Brocky
Member #: 224
Katy TEXAS
Alright Guys,
I'm just putting my timing cover back on after fitting a duplex chain.
Do I need to modify the cover so it clears the duplex chain ?
Its a standard metro turbo cover. I did a searh but nothing came up. Just seems to ring a bell...
Brocky
johnK
Member #: 690
Norfolk
theres a little "indent" at the bottom of the case underneath the bottom seal that needs knocking "outwards" to let the chain past - worth placing the cover on without a gasket to see if it clears here and also if the tin "semi circular" oil drain piece around the breather outlet clears the cam gear/chain
did you pop the two countersunk bolts in the bottom plate as well?
JK
If Carling made Mini engines
Brocky
Member #: 224
Katy TEXAS
Thanks for the clarification John,
Yeh, I did counter sink the 2 holes on the bottom of the front plate and fitted the counter sunk cap screws from minispares.
I will do what you said and then get out the big hammer !
Brocky :)
yeah, give it a whack
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5765
Brocky
Member #: 224
Katy TEXAS
Thanks Joey,
Hammer time lol !
Brocky
Member #: 224
Katy TEXAS
Alright guys,
Lesson learn't...wish Id done this sooner, but had to quickly put in the spare short engine just before I left for the states a couple of years ago, and until after I put it on the rolling road forgot it only had a simplex timing set up !
I have just shipped the car out this December and have been happy sorting the motor.
Well I've just been for a spin after fitting the duplex and timming it in properly on my turbo motor, MG NA cam. I timmed it in at 109.5 with a 3 degree offset key, and there feels to be lots more power higher up the rev range, and the engine feels much more responsive.
I measured the standard set up before and it was about 5 degrees out.
Previously torque had been dropping off from 4.5 - 6 k, on 10 psi and was only giving about 115 bananas at 6k and 110 curly wurlys at 4.5k. 1310 motor. 8.4 cr , cossy intercooler and benross big valve head.
Probably due to the cam being out and the simplex stretch at high rpm.
While it was in bits I also rebuilt the carb and put in a blanked butterfly and binned the poppet valve and put in a fabricated jet holder.
Initial mixture adjustment was a pieces of cake and after 10 miles or so I pulled a plug and it was orange brown with a little black.
I prefer to run a little rich. Moter pull well even off boost.
I think I should see a good improvement next time I get it on the rollers.
Plan is to fit a MJ next, as I put on one of toms pulleys and brackets while I had the the timing cover off. Have got all the ford bits just need to order up the v4 mj. Thinking need to fit a wide band lamda sensor as well.
Really is great to get the car over here after a 2 year break.
Brocky
Edited by Brocky on 24th Jan, 2010.
