| Home > Help Needed / General Tech Chat > Float Vent Connection | |||||||
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
28th Sep, 2010 at 01:09:31pm
I have converted an Nat Asp carb to use on the turbo.
28th Sep, 2010 at 01:15:01pm
No, the float vent is not the same as the part throttle lean off. It is just that a float vent.
28th Sep, 2010 at 01:21:35pm
ok thanks wil.
28th Sep, 2010 at 01:32:32pm
Seems a bit odd. The float bowl isn't exactly sealed, i.e. if you pump fuel in at a pressure above the needle valve release pressure it fills the bowl up then squirts fuel out of the jet.
28th Sep, 2010 at 03:30:07pm
I know. Confused me too. But fuel was pouring out the jet and i'd tried everything else. SO I unblocked the float pipe, air fizzed out and problem solved. |
28th Sep, 2010 at 08:16:47pm
If I now try to block the pipe back up it causes fuel to dribble out of the jet (when needle removed)
28th Sep, 2010 at 08:26:23pm
Right, your problem is that your fuel pressure is set too high.
28th Sep, 2010 at 10:48:26pm
Ive had a faulty needle valve before that caused the same problem.
29th Sep, 2010 at 07:39:07am
Good point Nic. Checking the fuel pressure will answer which one it is. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
30th Sep, 2010 at 08:54:57am
Right, Actually sorted now.
30th Sep, 2010 at 09:16:23am
Even with the drilling blocked up no fuel should come out of the jet (with the engine off and pump on).
