| Home > Help Needed / General Tech Chat > trigger wheel pulleys | |||||||
![]() 871 Posts Member #: 2590 Post Whore Croydon |
29th Oct, 2010 at 09:05:37pm
i have seen (trigger wheels) sell a Aseries specific trigger wheel (tophat style) just wondering if any one has one fitted? also does anyone have one fitted with the jonspeed bottom pulley?
![]() 716 Posts Member #: 9077 Post Whore Cheshire |
29th Oct, 2010 at 09:41:49pm
Do you mean the bolt on ones? I have one. On 2nd Nov, 2010 wil_h said:
I think it's probably a given that all people who own pink cars like it up the Gary. On 14th Jan, 2011 rubicon said:
please dont put a batty kit on it, il have to by internet law, Report you to barry boys.com |
29th Oct, 2010 at 09:54:31pm
sounds like a typical answer from that bunch On 26th Oct, 2004 TurboDave16v said:
29th Oct, 2010 at 10:06:52pm
If you run without a torsional damper on a 1275 you are taking a risk.
29th Oct, 2010 at 10:26:23pm
My thoughts are as follows, use an mpi pulley with its damper, and get carl to make you a new supercharger pulley. then use something like the specialist components trigger wheel that bolts on top of the existing pulley.
Edited by minimole23 on 29th Oct, 2010. On 7th Oct, 2010 5haneJ said:
29th Oct, 2010 at 10:35:29pm
i dont really want to buy another pulley,
29th Oct, 2010 at 10:45:52pm
The problem you might find is having the supercharger bottom pulley and trigger wheel fouls the radiator, have you accomodated for this?
29th Oct, 2010 at 10:48:48pm
i still do have room between the bracket and the pulley not to much though |
30th Oct, 2010 at 05:03:24pm
If you do not rev your engine above 5700 rpm then in theory you should not need a damper, I think vizard states that the damaging harmonic frequencies occur at 5750 and 6200 rpm, though the resonance is pushed higher up the rev range by the addition of lightweight flywheels and the like. Therefore if you are not caning it all the time you may get away with it, however if you do cane it a lot the fatigue life of the crank will more then likely be reduced, as well as other things.
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
30th Oct, 2010 at 05:14:34pm
Anyone ever added the damper to a 998? or know the effects.
30th Oct, 2010 at 07:18:31pm
late A+ 998s were fitted fith dampers from the factory. On 26th Oct, 2004 TurboDave16v said:
30th Oct, 2010 at 07:18:34pm
30th Oct, 2010 at 07:35:34pm
I run a damper on my 998... the outside has been machined to take the SC belt. and my trigger wheel bolts between the pulley and the timing cover... I run a supercharger and I don't care the TB is on the wrong side.
30th Oct, 2010 at 07:35:56pm
but then I dont run an eaton I run a supercharger and I don't care the TB is on the wrong side.
