| Home > Help Needed / General Tech Chat > Megasquirt Tacho / Rev Output | |||||||
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
17th Nov, 2010 at 11:46:57am
I'm going to be using Megasquirt 1 to directly drive the EDIS coil packs.
17th Nov, 2010 at 12:05:42pm
Essentially, yes, that should work.
17th Nov, 2010 at 12:20:19pm
The alternative is to get a rev counter out of an MPi mini and just connect a single coil ouput. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
17th Nov, 2010 at 06:31:15pm
Rod, do you have a web link to programming one of the CPU's spare ports to send the signal direct?
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
17th Nov, 2010 at 07:08:33pm
You can do it from within whichever tuning software you're using, at least I think that's what Rod is referring to.
17th Nov, 2010 at 07:19:13pm
Dan,
17th Nov, 2010 at 07:19:17pm
Ah ok cheers Carl, found it in tuner studio.
17th Nov, 2010 at 07:20:20pm
Well, it didnt work with my tacho, but you may be lucky.
17th Nov, 2010 at 07:36:00pm
Posts are a bit out of order......
Edited by Rod S on 17th Nov, 2010. Schrödinger's cat - so which one am I ??? |
17th Nov, 2010 at 07:41:55pm
On 17th Nov, 2010 dan187 said:
Also, (on a slightly related topic) what dwell setting have you guys successfully run when driving EDIS coils from Megasquirt? I started at 3.5mSec, blew a coil up so now run 2.8mSec. Edited by Paul S on 17th Nov, 2010. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
17th Nov, 2010 at 09:05:37pm
ah ok Rod,
17th Nov, 2010 at 09:59:44pm
Essentially yes....
17th Nov, 2010 at 10:57:12pm
On 17th Nov, 2010 Rod S said:
Posts are a bit out of order...... If you use the CPU pinout direct, you need the circuit that replicates a coil (ie, including the transistor that protects the CPU) to provide the same voltage spike as a real coil would. It's the one above the diode solution in the Extra manual. Hope that makes sense...... Interested to know what the difference is between the MS2 Extra output from the CPU and the output from MegaJolt, surely they are the same? |
18th Nov, 2010 at 07:51:10am
On 17th Nov, 2010 Carl S said:
Interested to know what the difference is between the MS2 Extra output from the CPU and the output from MegaJolt, surely they are the same? I wouldn't think there is a difference Carl. The code is simply telling that CPU pin to become a pulsed output with one pulse per 1/2rev (it can also be set to 1 pulse per rev) instead of its normal duty as a warmup telltale light. The way you set it up is a very different menu for MS2 in TunerStudio or Megatunix but the end result should be the same. I assume you have yours built now ??? If so, run it slow on the JimStim and watch the middle LED - it should show the RPM pulses just like the two outer LEDs now show the two halves of the coilpack being fired alternately in resonse to those ports now being programmed as Spark A and Spark B. If it flashes in line with RPM pulses, it suggests something is wrong with the transistor/coil circuit (the use of a relay for the coil/inductor is a bit naff but should work), if it isn't flashing but is still indicating warmup, the code isn't set right. I haven't actually wired mine up for this yet as I had another use in mind for D15/PM5 (it's programmable for lots of other uses too....) but everything else I've swapped around in the Extra code does what it should. I'll take the laptop out later and reset mine (it's just showing warmup at the moment) and see if the LED starts to flash as I would expect. (edit - typo) Edited by Rod S on 18th Nov, 2010. Schrödinger's cat - so which one am I ??? |
18th Nov, 2010 at 08:50:43am
Well the reason I ask is because my tacho did work with the MJ tacho signal, but it doesn't work with the MS output, which is why i'm scratching my head over it, hence why I wondered if there was a difference.
18th Nov, 2010 at 09:06:55am
On 18th Nov, 2010 Carl S said:
Maybe the FIDLE pin is unsuitable for use? The Fidle (PM2) is listed in the table as available for tacho or programmable for whatever else - it's just another PM* port on the CPU. The only difference is it doesn't have the LED that PM3,4,5 have to give you a simple look see if it's doing what you want. Have you gone direct to PM2 or have you come off the Fidle out ??? The existing FIdle circuitry "may" invert the signal relative to the CPU port - I'll have a look at the schematics later. On 18th Nov, 2010 Carl S said:
P.S I've had the MS unit built for quite a while now, I just havn't installed it as I was getting ignition issues. I will have another go at getting it running this weekend. Out of interest, what were the ignition issues - may help to know for Dan when he's setting his up. Schrödinger's cat - so which one am I ??? |
18th Nov, 2010 at 10:31:02am
I was getting an extra missing tooth appearing on the tooth logger. I believe it's to do with the VR sensor's polarity but I tried switching it around to no avail. It would either run and present the extra tooth, or not run at all with the polarity reversed.
Edited by Carl S on 18th Nov, 2010. |
18th Nov, 2010 at 12:32:19pm
Re the missing tooth, it may be the VR pot settings - on mine they are very sensitive and have to be different on the car's real VR sensor compared to the JimStim simulation.
18th Nov, 2010 at 12:57:51pm
I had a fiddle around with the VR pots but they didn't make much difference, if any. I read the MS manual about how to adjust them, but it just talks about the actual function of what the pots are for, rather than how to get settings which are right for the VR sensor. Maybe i'm missing something here.
9th Aug, 2011 at 06:55:53pm
Carl did you get to the bottom of this ive been trying to do the same as you. I built the extra circuit external to ms (inside an old relay) with everything connected as per circuit diagram no tacho but i happened by accedent to bridge a wire whist messing about with it and i got a tacho signal perfect
Yes i moved to the darkside |
9th Aug, 2011 at 07:57:42pm
No sorry Brett, the MS is still out of the mini at the moment, and i'm also 200 miles from the car so can't do a great deal at the moment. The extra tooth issue is crushing my progress but I have a few ideas to try when I get home to Devon again.
9th Aug, 2011 at 10:34:13pm
Just think in it over( im at work ) i could us an ignitor chip for now wired up as a coil driver i dont think the transisters im using are working as they should (or more likily wired up wrong)
