Home > For Sale > Clearing out A series bits
Owen
Member #: 6496
Somerset
Hi chaps,
Got a few bits for grabs.
- MED Low distortion roller tip rockers (around 1000 miles use) - £200.
- Complete megajolt set up, TPS version. ECU, loom, crank sensor and bracketry, TPS bracket for weber 45, TPS, EDIS unit, coilpack, spark plugs. Was taken off (and mapped) for a race 1380 engine - £500
- Weber 45 (jetted for race 1380), New maniflow 7" steel inlet manifold (modified for evacusump system), New ITG filter - £300
- Maniflow stage 2 LCB - Sold!
- Bespoke tubular mini subframe. Designed for front mount rad. Powdercoated blue - £300
O.
Edited by Owen on 21st Nov, 2010.
On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair
philc
Member #: 1346
bromsgrove
pics maybe help your sale
the_soon_to_be
Member #: 1600
Portsmouth, Hampshire
pics of the subframe pleasse
hoppinmad
Member #: 8537
Nr pottersbar herts
PM sent re maniflow lcb
dan187
Member #: 6724
Wootton Bassett
Would you like to split the EDIS from the megasquirt?
I'll take the crank sensor and bracketry, EDIS unit and coilpack. (Do you have the spark leads?)
1275 EFi Turbo
JT
Member #: 637
Hertfordshire
picture of the subframe would be nice mate.
My build thread..
george91
Member #: 8932
I'll have the weber mainfold if you split.
I'd be interested in the carb and filter, so.... :)
Owen
Member #: 6496
Somerset
Will try and get some pics up of the lot asap guys.
steve01
Member #: 9201
do you still have the lcb if so does it have the y piece? and is collection next saturday ok if its still available?
Steve
Owen
Member #: 6496
Somerset
Hi Steve,
Sorry but someone already has 1st dibs on the manifold. If it falls through you are next in line.
Owen
Member #: 6496
Somerset
Pics for all:
Scruffy
Member #: 328
Seaford Rise, South Australia
How much does that subby weigh please?
On 5th Sep, 2011 Vegard said:
if dan is after the other edis stuff, i might take the weber tps bracket
do you have a picture?
Owen
Member #: 6496
Somerset
LCB sold!
tadge44
Member #: 2500
Buckinghamshire
Are they 1.5 rockers ?.
Owen
Member #: 6496
Somerset
yes they are 1.5:1 rockers.
