| Home > Help Needed / General Tech Chat > Not running right | |||||||
347 Posts Member #: 9075 Senior Member Peterborough |
20th Nov, 2010 at 01:14:55pm
My NA 998 has been running a bit off as of late. It revs (not sure how high, no tacho) and makes a shit load of noise but barely moves.
Edited by DaveVader on 20th Nov, 2010. |
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
20th Nov, 2010 at 01:27:05pm
Have you taken it out in the rain? Could be the ignition system is wet and not sparking well? |
20th Nov, 2010 at 01:28:06pm
Most likely the condenser.
20th Nov, 2010 at 01:44:25pm
I've replaced the condensor about 3 weeks ago.
20th Nov, 2010 at 01:52:35pm
Where did you get the "new" condenser from?
20th Nov, 2010 at 01:57:34pm
erm, minispares I think, or was it minisport.
20th Nov, 2010 at 06:12:53pm
crap on the points clean these,
20th Nov, 2010 at 07:23:57pm
Will sort all that in the morning and let you know.
21st Nov, 2010 at 09:44:58pm
Well, I didn't get round to doing anything today as I worked on the project instead.
388 Posts Member #: 442 Senior Member Manchester |
22nd Nov, 2010 at 07:47:52pm
Is the screw tight on the points? Is the Cam on the points worn? |
22nd Nov, 2010 at 08:02:53pm
Well I broke down on the way home from work (my fault really) nursed it home. Replaced my coil just now and it's running 10x better. Still not 100% right but I think that could be either condenser (probably not unless the coil takes that with it) or just my points need setting a little better.
22nd Nov, 2010 at 08:47:33pm
On 20th Nov, 2010 BENROSS said:
crap on the points How often should you do this?
Edited by John on 22nd Nov, 2010. If something is worth doing, it's worth doing half of. |
22nd Nov, 2010 at 08:48:18pm
BTW the liquid in your coil is oil to keep it cool :) If something is worth doing, it's worth doing half of. |
22nd Nov, 2010 at 09:10:43pm
Oh, really? Sounded a lot thinner than oil.
23rd Nov, 2010 at 06:33:56am
you've probably cooked the old coil and boiled the oil until it has broken down into piss. On 11th Feb, 2015 robert said:
23rd Nov, 2010 at 08:28:25am
Sounds about right. When you shake it it just sounds like there is a load of water in there. The coil I replaced it with is much more solid. |
