Home > Introduce Yourself > revcounters just wont work? HELP
wng691s clubby
Member #: 9252
Cleethorpes
hi there i had a set of smiths three dial gauges in my 1977 clubman which worked great for a couple of months but then i noticed that my revcounter stoppped working so i took my dashboad off and tested the connections which seemed fine so after hours of trying to figure it out i came to the conclution that my clocks were past it. I searched ebay and managed to find a set of magnolia cooper s clocks (nippon)after the seller reassuring me that they worked fine hed just written off his car. But the recounter on these dosent work and surly 2 sets of clocks cant be nakered any1 got any ideas please help its really bugging me lol.
Done now needs redoing lol
Your wiring is fucked mate.
Unfortunately there is no way we can diagnose a wiring fault of this kind without testing all your earths, feeds and connections
Paul
hazpalmer
Member #: 9038
Carlisle, Cumbria
get your fluke out and start testing *wink*
Most likely the wiring, but aren't the later S clocks off an MPi and hence different.
It's not uncommon to have knackered clocks, rev counters especially. However, the revcounter is one of the hardest things to check what's wrong if you only have a multi-meter. You need a scope and a suitable sig gen.
I'd try running a new feed for 12V and the coil signal first off.
Hello and welcome
I think the newer clocks won't work with your car.
Anyhow, I'd check the wiring onto the coil for a start. Its quite common for the wire to break at the spade connectors. Next step will be to get the test leads out and start tracing
wng691s clubby
Member #: 9252
Cleethorpes
thanks guys for the replies. iv tried putting a new supply from the coil to the rev counter but made no difference and iv fed a new permanent live to the clock still no difference and i have tested the original wires and they seem fine.the pcb board on the back of the clocks is like new is i dowt its that. Thanks for the welcome apbellamy i should of introduced my self lol will do properly sortly my apologies
wng691s clubby
Member #: 9252
Cleethorpes
the rest of the clock cluster works fine ie fuel gauge temp speedo.
Have you got a multimeter?
wng691s clubby
Member #: 9252
Cleethorpes
yes i have Tom
OK then
First set it to volts, check you have battery voltage supply to the rev counter
Now set it to ohms, check there is a good earth by measuring across to a good earth point on the car body.
Finally measure the black/white wire from behind the clocks to the negative side of the coil, this should be LOW resistance.
wng691s clubby
Member #: 9252
Cleethorpes
i shall give this a try tom thanks for your time i have test the wire before but i shall give this a try tomoz and get back to you all.
wng691s clubby
Member #: 9252
Cleethorpes
i tested all of these tom and all seems fine
Graham T
Member #: 1106
Hungerford, Berks
Could your car be wired for the older type inductive loop rev couter?
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10381
See last post in this thread.
’77 Clubman build thread
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=618189
Siamese 5 port EFI testing
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=611675
wng691s clubby
Member #: 9252
Cleethorpes
found that wiring loom was different to later cooper s sorted now lol
