Home > Help Needed / General Tech Chat > Rear Brake Effeciency
insamoufonyx
Member #: 7071
Nailsea, Near Bristol
All,
Having a issue with my rear brakes for sorting my MOT,
Basicly its not meeting the effeciency requirements on the footbrake rears or handbrake.
The backplates, springs, cylinders, pads and drums are all brand new (15miles use max)
could it just be a case of it need wearing in? i dont really drive the car so they dont get used.
i cant see what else it could be, the handbrake is pretty crap!
JT
Member #: 637
Hertfordshire
hi
have you adjusted them propoly?
My build thread..
insamoufonyx
Member #: 7071
yep, tried the adjuster up top and didnt really seam much different, just caused massive drum drag,
there just doesnt seam to be any 'adhesion' between the pads and drums.
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
Is there crap on the shoes/ drum?
Know it sounds basic but I took one apart once and some grease from the wheel bearing had got into the drum and made a right mess fucked the shoes up
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
insamoufonyx
Member #: 7071
one of the first things i checked, cleaned it out about 6 times with brake cleaner
Anton
Member #: 764
Staffordshire
shoes in the right way round?
whip the drums off, give them a blast with brake cleaner, and a run round some emery cloth, if possible leawe the drums of and outside in the weather overnight to get a little surface rust,
If they are cheap shoes its worth roughing the surface of those up with the emery too in a sideways motion.
some of the cheap shoes can be quite hard and take a while to bed in, tdoing the above will help get them started,
insamoufonyx
Member #: 7071
ok il give that a go tommorrow joe, might pick up another set of shoes tommorrow just incase, and yeh the shoes are the correct way around, they seam to have high and low spots, starting to be supicious of the quality of the pads.
michaelsanderson
Member #: 9234
Is it the rear brake efficiency under foot brake we're talking about or soley handbrake?
insamoufonyx
Member #: 7071
both
dan187
Member #: 6724
Wootton Bassett
check the lever arms are round the correct way. I had them reversed and it made the difference between pass and fail
1275 EFi Turbo
