Home > Help Needed / General Tech Chat > Read Beam and coilovers.
mr_incognito
Member #: 2135
plympton, plymouth
I have read through a few previous threads below but cannot make my mind up.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=360394
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=326928
A rolling shell I just bought comes with new minispares alloy rear beam and gaz coilovers (on the back only),
The car is a going to be a “fast road car”, has a few bits like the rear bins cut out to lighten and interior is stripped, not bothered about comfort as long as it drives well. I am inclined to try the coilover because its all built up, but peoples opinion seem to vary alot.
Is there any trick to setting these up, or do people still think stick with the subframe for a road car.
I have protech rear shocks, 125lb springs and a home made rear beam and the handling is fantastic. The car feels better balanced then it did with a heavy old subframe.
Hope this helps.
That looks shiney:) What does the rest of the car look like:)
eden7842
Member #: 8852
leicestershire
trial and error + personal prefrance mate
I think i will be going for one of carls beams this summer.
Mini_the_minx
Member #: 9077
Cheshire
Totally down to you mate, what works for one doesn't work for another.
Only downside to a beam is if you have a dtm you have to find another way to mount it.
I'm sure its the same for any exhaust as they all hang from the subframe
Mini_the_minx
Member #: 9077
Cheshire
Yes but with my DTM if I were to get a rear beam I'm have to hang it and then bolt it to the boot floor
