| Home > Wanted > Standard rear camber brackets | |||||||
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
8th Mar, 2011 at 11:57:01pm
Standard rear camber brackets posted or local collection
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
9th Mar, 2011 at 09:59:09am
Ive got some, I'm in chippenham On 15th Jul, 2009 fastcarl said:
the pissed up clown stood back up, did a twirl and left bollock naked, |
9th Mar, 2011 at 05:27:57pm
Good times. I'll be back from uni weekend of the 19th March. I'll PM you closer to the time and arrange to come over.
9th Mar, 2011 at 06:17:00pm
9th Mar, 2011 at 10:06:34pm
Waste of time unless you are going to shim the radius arms too On 5th Sep, 2011 Vegard said:
9th Mar, 2011 at 11:17:45pm
Scruffy could you be more specific please?
10th Mar, 2011 at 11:12:23am
The biggest gain suspension wise on a Mini is the rear tracking and its relationship to the front. Therefore you need to either use tracking/camber brackets or use shims under the radius arm brackets to achieve the correct geometry. So yes the Minispares shims! Edited by Scruffy on 10th Mar, 2011. On 5th Sep, 2011 Vegard said:
10th Mar, 2011 at 11:45:05am
I see your point but if I just want a standard setup, then simply fitting some original brackets will be no worse than a factory mini? |
10th Mar, 2011 at 08:09:58pm
Yes but the trouble you are going to to fit them is the same as fitting adjustable tracking brackets and these will transform your handling! On 5th Sep, 2011 Vegard said:
