| Home > Wanted > Drivers Side Radius Arm | |||||||
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
19th May, 2011 at 10:34:37pm
Basically all the bits in this picture. Mine appears to have a crooked hub shaft and also has seized at the radius bearing.
1300 Posts Member #: 829 Post Whore essex |
19th May, 2011 at 10:36:46pm
your have too remove pipe to take arm off 1293 Turbo mini
19th May, 2011 at 11:43:47pm
damn, why's that? which bit requires that? |
19th May, 2011 at 11:47:01pm
if you pipe clamp the rubber hose that will stop the fluid leaking out 1293 Turbo mini
