| Home > Beginners Tech > T2 Queries | |||||||
![]() 259 Posts Member #: 9335 Senior Member Bromley, SE London |
2nd Jun, 2011 at 05:55:35pm
I'v just rebuilt my T2 (how to thread coming soon), but have a few questions.
Edited by carts60 on 2nd Jun, 2011. |
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
2nd Jun, 2011 at 06:16:29pm
you know i've been reading lot of your posts and it seems that we are building almost identical engines On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
2nd Jun, 2011 at 06:25:50pm
Ha glad i wont be alone jumping in at the deep end mate. Where are you from? |
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
2nd Jun, 2011 at 08:45:52pm
On 2nd Jun, 2011 carts60 said:
I'v just rebuilt my T2 (how to thread coming soon), but have a few questions. I'v spun the turbo iteslf around it the housing so the oil feed is now at the top and take off at the bottom. Only problem is that the actuator mounts are now well off. Whats the solution to this? Drill and tap some new holes? Also, what pressure is the standard T2 actuator set to? I know it boosts to a max 15psi, but i really only want to be running 10-12 as its a daily drive and i dont want to go make the turbo shit itself. Can i set it to boost from different pressures? What does changing the actuator arm length do - ie showing more or less thread? yeah i had to drill and tap new holes for the actuator and build a new bracket for it. standard actuator is 10 psi, you might be able to tighten (less thread) the arm like you say to get the extra couple of psi. |
2nd Jun, 2011 at 09:04:17pm
Smashing. Thats cleared that up. |
3rd Jun, 2011 at 08:14:55am
You can run boost pressure higher but you loose efficiency, it runs out of puff (amount of air it can effectively push at said delta pressure) and just ends up
3rd Jun, 2011 at 01:39:06pm
Ha glad i wont be alone jumping in at the deep end mate. Where are you from? Swindon mate, im a complete novice at anything mechanical - but luckily my dads a total expert
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
3rd Jun, 2011 at 06:20:23pm
There are 2 generation of T2 fitted to the R5, earlier one are not water cooled, later one are. Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
3rd Jun, 2011 at 08:03:43pm
Mine's definitely water cooled. Heres a pic so we can clear up which is oil and which is water feed.
4th Jun, 2011 at 05:32:39am
Yes (mine is not water cooled and I have the large pipe) Rusty by nature
with the same power band in mind (120 - 130bhp)
