Home > Help Needed / General Tech Chat > Is my dump valve broken?
dan187
Member #: 6724
Wootton Bassett
I've just fitted a bosch recirculating dump valve. I noticed today that the manifold pressure wasn't negative at idle so looking around for loose pipes. Turns out the vacuum pipe on the dump valve I the cause and it's because the dump valve is sucking past the valve. How're they built? Shouldn't the vacuum pipe connect to a diaphragm? Have I split the diaphragm?
1275 EFi Turbo
Have you got it fitted the right way round?
^^^^ as above
dan187
Member #: 6724
Wootton Bassett
I think so. I put it so that the spring resists the high pressure side.
The vacuum sucks through both sides although the side I've put to atmosphere sucks the most. See my turbo build thread below for a pic of the setup. It's on the last page.
1275 EFi Turbo
The Bosch one is a very basic diaphragm type - diaphragm on the sensor side and simple piston on the "dump" side.
Just look in from the 90 degree angled dump side and you will see both and see if anything is wrong.
You can also check the spring/piston by pushing it with a large round bit of wood from the side opposite the sensor line and watching the result through the 90 degreee port.
The side that the boost vents to should not be under vacuum. Not sure how you have plumbed it to get this.
Large bore hose stub to the flat side of piston goes to boost duct between intercooler and plenum, or off the plenum.
Other large bore hose stub usually directed into the duct before turbo after air cleaner.
Small bore hose goes to somewhere on inlet manifold.
interestingly the SAAB 9 5 has a solenoid in the vac line that is shut during cruse preventing the valve lifting
found this, which might be usefull to you.
http://www.vaglinks.com/Docs/Misc/VAGLinks...erter_Valve.pdf
I have also checked the two valves I have. Both look identical, but have different part numbers. 0 280 142 114 is an upgraded item apparently with a tougher diaphragm fitted to the Audi TT. It certainly has a stiffer spring than the 0 280 142 106.
Found the pic in your build thread, and it looks to me that you have it plumbed in the wrong way round, but the picture does not show the flow direction well enough.
Why should it need this though?
My logic is that on both sides of the valve you have vacuum on cruise, and on one side you also have the spring pressure holding it shut. Certainly I'm pretty sure the one on my 205 is shut on cruise, as when I've run a non-recirc type that was also shut on cruise.
dan187
Member #: 6724
Wootton Bassett
Cheers for linking i'm on my phone. The pipe you can see in it's entirety is the high pressure side. Is that not right?
1275 EFi Turbo
The valve shoud never be exposed to vacuum (excluding the smallest connection), if it is, there is a problem, since the vave is connected to the boost pipes before the throttle. At cruse there may well still be some 'boost' since the throtte is only partly open, and the exhaust gasses are still driving the turbo. so with a posative pressure trying to push past the piston and a vacuum acting on the diaphragm, the only thing really holding the vave shut is the spring rate. Again it depends on the valves since there are a few different types that all look identical from the outside. If you read that document I linked to, it shows graphs of the three different bosch valves he tested and the 108 is full open at a relatively low vacuum.
The SAAB workshop manual clearly describes the contro of the soenoid for the 'bypass' valve at cruse
dan187
Member #: 6724
Wootton Bassett
According to sprocket's photo I have plumbed it wrong but I'm not sure how me changing it round will solve my problem. Surely there should be no air getting in or out of the diaphragm that the vacuum pipe connects to. That's because the pipe connects post throttle. So currenty it's just like having a leak in my inlet manifold.
1275 EFi Turbo
Read the document I linked to earlier!
Johnny
Member #: 6926
Accrington
so would you connect the pipe from the plenum DV takeoff into the one opposite the vaccume pipe on the DV?
From the diagram it looks as if your recirc valve is on backwards, so any boost is pushing the piston open and going back through the system, pressurising the inlet side of things, along with said vacuum pipe. Thats my theory anyway!
Johnny
Member #: 6926
Accrington
according to that disgram i have mine connected wrong, but it still works. However mine dumps to the air atm.
dan187
Member #: 6724
Wootton Bassett
I according to the diagram mine was on backwards but i cant really see what difference it makes to the operation. Either way that's not the problem. It seems my diaphragm is split but only a little. So that if I suck on the little vacuum pipe it sucks air through the rip. But if I blow on the vacuum pipe it pushes the diaphram against tha valve wall and self seals.
It works quite well because my car is running a bit rich off boost so this mean I'm getting extra air off boost only. The dump valve only works because I have it plumed in the wrong way round. So it opens purely due to the pressure difference across the spring an not by the vacuum opening the piston.
So I'm going to leave it as it is for bow and get a spare in case the rip gets worse and leaks on boost.
1275 EFi Turbo
You know how it should be plumbed and you know how you have it is wrong. You know The diaphragm is split but you are going to leve it even after asking advice as to whether it is broken?
why bother asking the question if you are happy with how it works for you now?
dan187
Member #: 6724
Wootton Bassett
Because only realised it was broken and plumbed wrong thanks to the links and comments.
1275 EFi Turbo
