| Home > Help Needed / General Tech Chat > High Compression EFI Turbo Daily | |||||||
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
14th Oct, 2011 at 01:01:41pm
Since finishing my 998 turbo build i've been eyeing up fuel injection as the next challenge. Also, I've taken that off the road for now (to be used next year for hill climbing) and started driving my 1275 N/A. I've finished uni and have a job at Dyson and s since I will now be driving the mini every day it made sense to go back to having a radio, sound-deadening material and seats that don't take 2 minutes to get in and out of.
14th Oct, 2011 at 01:13:34pm
My personal view would be stick with the MS2 initially (don't you already have one ???).
14th Oct, 2011 at 01:19:25pm
Having setup and used both, I find the MS3 far easier. Just a standard sequential setup.
14th Oct, 2011 at 04:26:28pm
On 14th Oct, 2011 Paul S said:
Having setup and used both, I find the MS3 far easier. Just a standard sequential setup. And for some the electronics is just too complicated. A fully built MS3/3X is as close to plug and play on the 5 Port as you can get. I will still use the MS2 on two of our cars, because we have them. You could use the MS2 as a standard sequential setup too but you wouldn't have staged injection available then. And there will be an MS2-based solution in the not too distant future that will be as plug and play as an MS3 and it would also be less expensive. Of course, that won't have the MS3-only features but will have all the MS2/Extra features built-in with a sealed case and connectors in a much smaller footprint. Jean |
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
14th Oct, 2011 at 10:00:28pm
I am very interested in this kind of build especially given the still high expectation on power output.
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
14th Oct, 2011 at 10:12:48pm
Certainly would need an efficient intercooler in good air flow.
14th Oct, 2011 at 10:18:32pm
if it dets, just drop the boost a bit :) On 28th Aug, 2011 Kean said:
15th Oct, 2011 at 08:50:18am
I've run 15psi on a wet manifold 9.3:1 no issues. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
16th Oct, 2011 at 12:38:36pm
Sorry chaps. Just have an ms1 I'm afraid. And the board is only built up for ignition. No bits for injection.
16th Oct, 2011 at 12:49:11pm
As long as you realise that the MS3/3X is an MS1 but with a couple of add-on boards and larger case.
16th Oct, 2011 at 05:46:12pm
Currently I've been swapping the ecu between my two cars and loading different profiles to achieve the settings.
388 Posts Member #: 442 Senior Member Manchester |
16th Oct, 2011 at 08:44:29pm
When i first read this post title i thought it was going to be about the iveco turbo daily. hahaha. Wasnt someone using a turbo off one of those? |
114 Posts Member #: 9645 Advanced Member South Wales |
20th Oct, 2011 at 01:55:44pm
I'm planning something similar for my 998, initially starting off with the ms to control the ignition and then hopefully the injection. I think I'm going to go straight for the ms3 rather than ms2 as well - hopefully this will be ordered this week. What are you planning for the inlet and exhaust manifolds? Are you going to side mount the turbo? I also have a gt1549, I'm not sure if this will be too big for the 998, but should be a straight swap for the 1444 anyway if spool up is too slow.
20th Oct, 2011 at 10:18:23pm
like the facebook page for diyautotune and get their 10% off code if you order by Sunday. unfortunately i don't have the money to order it now :(
