| Home > Help Needed / General Tech Chat > T2 turbo with two actuator take offs? | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
16th Feb, 2012 at 10:45:25pm
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
16th Feb, 2012 at 10:47:01pm
ignore it.
16th Feb, 2012 at 11:01:25pm
its just a pressure reference you want to use the one with the sticker next to it ( dont block the other though Yes i moved to the darkside |
17th Feb, 2012 at 10:06:59am
Ok so I couldnt use it as a second take off for something like a bleed valve instead of having a t piece??? On 10th Mar, 2012 theoneeyedlizard said:
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
17th Feb, 2012 at 10:51:05am
No it's just the opposite side of a sealed diaphram |
17th Feb, 2012 at 03:20:49pm
ok, thanks for the info guys :) I'll leave it and use the one at the top then.
