Home > Help Needed / General Tech Chat > Turbo Whine
dan187
Member #: 6724
Wootton Bassett
On the way home today in the turbo I heard a pop and then lost power and developed a whining noise.
When home, I took off all the pipework and had a look into the compressor and it seems ok. Shaft had normal play. I think a pipe might have popped a leak but why now do I have a whine? Similar to the noise this chap has.... http://www.youtube.com/watch?v=F_FXekG16vM&feature=related
I am able now to get full boost pressure but I get very little induction noise compared to before and have the whine.
Any ideas?
1275 EFi Turbo
dan187
Member #: 6724
Wootton Bassett
perhaps i still have a boost leak? It sounds a lot like an air horn?
1275 EFi Turbo
bennyy
Member #: 9037
Doncaster, yorkshire
Simon had a whine like the vid at Avon, turned out to be the plenum>carb gasket, worth s check.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
dan187
Member #: 6724
Wootton Bassett
ok cheers. i'll have a look tomorrow and do a double check of pipes and gaskets.
This video also has similar sound.
http://www.youtube.com/watch?v=D4HvFW_6mjY...player_embedded
1275 EFi Turbo
Check the suction. Side loose hose
Thats what mine sounded like when the boost hoses popped off.
That's whatine sounded like when the bolts holding the exhaust housing worked loose and munched the turbine.
dan187
Member #: 6724
Wootton Bassett
ah, so it's either really easy simple problem of hose loosening or a fooked compressor or turbine wheel.
When your turbine got munched were you still able to get full boost?
1275 EFi Turbo
Briefly.
Not that I contined for long with it making such a racket.
dan187
Member #: 6724
Wootton Bassett
So finally got time to look at the car last night. Turned out to be the gasket between the two halves of the plenum. All sorted now. Cheers
1275 EFi Turbo
Phew!
jlay
Member #: 1742
essex
cool simple and cheap problem to fix. I dont mint those type lol
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
bennyy
Member #: 9037
Glad its sorted. Hours was spent at Avon trying to find the problem. Everyone was stumped lol.
dan187
Member #: 6724
Wootton Bassett
Exactly my thoughts :)
1275 EFi Turbo
