| Home > Help Needed / General Tech Chat > Crank position sensor polarity | |||||||
![]() 562 Posts Member #: 9285 Post Whore Oxfordshire |
8th Oct, 2012 at 05:59:25pm
This may be a silly question, but i couldn't find an answer on the autosports site or here. Basically i need to know how to tell the polarity of the crank position sensor. Its from a fiesta and it has 2 pins, but with no indication as to which is + and -
282 Posts Member #: 1404 Senior Member The Netherlands |
8th Oct, 2012 at 06:20:12pm
I don't know how to measure it.
there is nothing wrong with a A-series that a turbo can't fix.
8th Oct, 2012 at 06:22:45pm
Thats what i was going to do, but it would be nice to try and do it just the once. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
8th Oct, 2012 at 06:56:11pm
Rod S explained which way round the go, but it was some time ago. Have a search. On 11th Feb, 2015 robert said:
8th Oct, 2012 at 07:09:56pm
I've tried searching Andy to no avail! Can't think of any other words to search My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
8th Oct, 2012 at 07:53:10pm
it will work both ways but one way is unstable and the timing jitters about the other is correct,
Edited by Brett on 8th Oct, 2012. Yes i moved to the darkside |
8th Oct, 2012 at 08:06:06pm
8th Oct, 2012 at 08:17:50pm
Ah that is what i was after brett, cheers! And i'm glad i'm not going mad Andy. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
8th Oct, 2012 at 09:11:52pm
It will only work correctly when wired correctly, yes they are polarity sensitive.
9th Oct, 2012 at 07:29:59am
Pardon my ignorance but I dint understand this falling/rising edge business.
84 Posts Member #: 2404 Advanced Member Braintree, Essex |
9th Oct, 2012 at 07:37:59am
Halfway down this page:
Geoff |
9th Oct, 2012 at 08:49:34am
This thread, second post
9th Oct, 2012 at 06:20:44pm
On 9th Oct, 2012 tadge44 said:
Pardon my ignorance but I dint understand this falling/rising edge business. Do I take it that we should be setting the 90 degrees away from TDC on the leading edge of the gap, rather than the middle of the gap?. The video I linked explains. The leading edge would be seen as a rising edge. The trailing edge would be a falling. However, if wired wrong that can also appear as the opposite, even though they arent. Edited by stevieturbo on 9th Oct, 2012. 9.85 @ 145mph
