| Home > Help Needed / General Tech Chat > Converting my 1293 N/A to Turbo | |||||||
313 Posts Member #: 9367 Senior Member Derby |
23rd Oct, 2012 at 09:56:01am
Hi guys,
23rd Oct, 2012 at 11:59:52am
Hi mate,
23rd Oct, 2012 at 12:03:12pm
My main question really is could the head be re used and the chambers opened out to suit. |
23rd Oct, 2012 at 12:06:41pm
Have a chat with Turbo Phil also have a look at his website as well. I have started posting on Instagram also my name on there is turbomk1golf
23rd Oct, 2012 at 12:22:26pm
You could open up the head to give the desired CR or you could use the 18cc pistons. However 37/31 valves means little meat between the valves which could be a weakness with a turbo. I would sell the head and get another one more suited.
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
23rd Oct, 2012 at 12:23:27pm
aren't the valve guides different in a turbo head? that and the cc is the only thing i can think off.
Edited by t@z on 23rd Oct, 2012. |
23rd Oct, 2012 at 01:13:51pm
On 23rd Oct, 2012 t@z said:
aren't the valve guides different in a turbo head? that and the cc is the only thing i can think off. edit & what paul said so i look smart ![]() http://www.twin-turbo.co.uk
23rd Oct, 2012 at 04:54:39pm
is 2mm of play in a GT17 too much? |
23rd Oct, 2012 at 05:46:56pm
Yes Drives
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
24th Oct, 2012 at 03:19:34am
Also, what carb have you already got? It is easy to convert a non-turbo HIF to turbo applications |
24th Oct, 2012 at 07:11:11am
it's a standard hif44 so yes I will look into it. I was reading about the conversion the other night. Is it really as simple as just building it with a turbo rebuild kit and machining the groove out of the body? |
24th Oct, 2012 at 07:37:03am
Can this be taken out by using a rebuild kit or is it worth steering clear?
On 23rd Oct, 2012 Paul R said:
Yes |
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
24th Oct, 2012 at 08:10:17am
I rebuild kit might fix the play, but I would be concerned that either the compressor and/or turbine wheel would be damaged to the the play. "So wat we gonna do tonight Brain?"
