Home > Help Needed / General Tech Chat > Stage 3 mpi tuning, advice please
jayme
Member #: 10547
Hi guys finished restoring my mpi cooper around 3 years ago and has been brilliant fun to drive over the summer.
Engine is completely standard but i have fitted spax coilovers and adjustable arms which have been properly set up and makes the car great to drive.
I have now got to the stage where in at uni, and when im home have a full time job in a cad office so can afford to hunt for some more power.
few pics
My plans are to remove the engine to start.
3.44 fd
x pin diff
swiftune sw5i
minisport adjustable timing gears
vmax stage 3 head
1.5 rockers
lcb
power boost valve
i understand i can expect to hit over 80 with this.
is there anything else i should consider, my engine has covered 56,000 miles and still pulls strong and has never caused any issues.
Thanks Jayme *happy*
Edited by AlexB on 8th Aug, 2013.
Instagram: bighill93
jayme
Member #: 10547
Also i intend to do the work myself to keep the cost down, i am fairly confident with anything mechanical.
3.2 fd with those wheels and tyre sizes IMO
jayme
Member #: 10547
Thanks
benross have i read on the forum you modify cylinderheads?
dan187
Member #: 6724
Wootton Bassett
you forgot to mention the turbo and Megasquirt on your list of mods? :)
Edit: Lovely car by the way
Edited by dan187 on 8th Aug, 2013.
1275 EFi Turbo
welshdan
Member #: 1111
s wales
I started tuning my mpi the same way. St3 head, 1.5 roller rockers, k+n induction, decent exhaust system, 52mm throttle body from a lotus elise modified to fit. Then overbored to 1360, sw5i cam, close ratio gearbox, 3.2 final drive, ported inlet manifold. It went really well until i had gearbox troubles, though im in the prosess of rebulding to that spec. Cheers, dan
jayme
Member #: 10547
Haha you have no idea how much id love to be posting about my TURBO build, i dont think this would be the best car to start that build *wink*
Did you ever have any fueling issues welshdan?
yea im a bit worried my box will throw the toys out of the pram so im going to give it a rebuild, do you mind me asking what broke in yours, from what i read its the bearings fail which is the problem so been looking into just replacing them. try save some money.
jayme
Member #: 10547
oh and a link to my a feature, some othe really cool stuff on it aswell.
http://www.autolifers.com/limelight-jayme-...-mini-cooper-s/
if anyone on fb give them a like.
Dan has a point, the Mpi boxes are notorious for being shit. Worth sorting that while the engine is out.
Your limit with the Mpi is the fuelling. 80 is probably a sensible target, but don't be surprised if you don't make it.
The only way to make real power is by fitting a more tuneable injection system.
