Home > Help Needed / General Tech Chat > Air filter/intake to turbo
Chris-G
Member #: 10229
Stroud
Trying to mock up my air filter pipe today but its become rather tedious. Ive tried a silicone hose through 90 degrees but its just too tight to the rad and bulkhead. I have some 57mm i.d neoprene ducting that fits better but i just cannot get it on to the turbo.
Its a metro t3 am im using a side mounted rad.
What are my options? and what have other people done with this set up? I cant be the only one to have had this problem?!
Do i fit 60mm i.d ducting and hope it clamps down ok?
Any help would be greatly appreciated :)
The T3 is outlet is 60mm, so I would go with that size hose.
Chris-G
Member #: 10229
Stroud
Thanks for that, everywhere on here that ive read says its 57mm? At least that solves my problem!
I've used 60mm in the past.
Not sure what you have been reading...
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=502853
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=371912
