| Home > General Chat > SD cards for logging MS3X | |||||||
30th Sep, 2013 at 01:07:34pm
with such a wide range what do people use?
30th Sep, 2013 at 01:27:04pm
Buy exactly what they say on the site i found ms3 to be quite picky i have 10+ memory cards and it didnt like any of them, the real time clock up grade is worth while for sd datalogging becauae.ms3 names and dates them all the same with out it hahaha Yes i moved to the darkside |
30th Sep, 2013 at 01:28:34pm
http://msextra.com/doc/ms3/sdlogging.html Yes i moved to the darkside |
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
30th Sep, 2013 at 01:48:09pm
i've tried two i had lying around. both work no problems. one was a micro in an adapter. I didn't realise the clock was available yet. must get one. it's a right pain without it. |
30th Sep, 2013 at 04:00:35pm
the rtc has been around for some time now
30th Sep, 2013 at 09:00:00pm
ah, anywhere in the uk sell them?
30th Sep, 2013 at 09:48:57pm
On 30th Sep, 2013 dan187 said:
ah, anywhere in the uk sell them? my sd card is a cheap old 256mb one. no speed rating on it i'm afraid. can't find the other one i used. are you using the ms3 for your vtec conversion or on a 5 porter? its was actually built for the skyline and was on and off for a couple months but imo the rb25 code doesnt work correctly so i bought some other stuff for that and this will be going on the mini vtec my cards are all new ish and high speed i had to buy a slow one for the ms3 it was only a couple ££ for a 2gb one from Maplins Edited by Brett on 30th Sep, 2013. Yes i moved to the darkside |
1st Oct, 2013 at 12:43:55am
so a slower card should be better them
1st Oct, 2013 at 07:05:18am
you can pick a time or size limit, i've set a 30 minute limit, these come out around 22mb (depends what fields you're logging (doesn't automatically record everything) |
1st Oct, 2013 at 07:20:27am
i see so there is no need to have to be a huge one then sounds like a 8gb one will be loads for me as ill check it after each run probably
