| Home > Help Needed / General Tech Chat > Custom inlet manifold, 998 | |||||||
113 Posts Member #: 9241 Advanced Member Edinburgh / Dumfries |
11th Dec, 2013 at 02:17:14pm
Hi lads,
12th Dec, 2013 at 10:13:36am
A whole day and no replies, dear me :( A few years ago you would have had a couple of pages by now. Sad.
12th Dec, 2013 at 10:22:08am
what Paul says.
78 Posts Member #: 9073 Advanced Member Edinburgh |
12th Dec, 2013 at 12:32:16pm
On 12th Dec, 2013 Paul S said:
As usual, there is an optimum inlet runner length/diameter. It really depends on the spec of the rest of the engine. A standard engine/cam/head will make the best torque with a runner length of around 450mm, but will be hampered above 6k rpm. Whereas a well modified engine with a big turbine will make best torque and rev to 8k with 250mm long runners. Interesting feedback Paul. How tuned to a particular rev band is the optimal inlet length (typically)? When you say runners, is that from the carb face to the head face of the manifold or does that include the port in the head? I was always intriqued by Vizards initial reports on the long inlet trumpet with the 90degree bend at the carb (I can't remember the name). It seemed to offer more torque with little compromise. Nial. |
12th Dec, 2013 at 12:39:16pm
A whole day and no replies, dear me :( A few years ago you would have had a couple of pages by now. Sad. It's likely people have read your's and Rod's signatures and thought better of it... On 11th Feb, 2015 robert said:
12th Dec, 2013 at 01:49:01pm
On 12th Dec, 2013 apbellamy said:
It's likely people have read your's and Rod's signatures and thought better of it... How did I get dragged into this thread (assuming you mean me Andy) - I have nothing to add on inlet manifold design as Paul has already posted a lot of information on the subject. If you don't like member's signatures, you can turn them off in the forum "control panel". Personally I think mine is much better than most
12th Dec, 2013 at 03:32:58pm
A few questions stemming from this...
Edited by Carlzilla on 12th Dec, 2013. On 26th Jan, 2012 Tom Fenton said:
12th Dec, 2013 at 04:18:02pm
On 12th Dec, 2013 Nial said:
Interesting feedback Paul. How tuned to a particular rev band is the optimal inlet length (typically)? When you say runners, is that from the carb face to the head face of the manifold or does that include the port in the head? I was always intriqued by Vizards initial reports on the long inlet trumpet with the 90degree bend at the carb (I can't remember the name). It seemed to offer more torque with little compromise. Nial. Typically you should expect over 90% peak torque in the range 4k to 7.5k with a 250mm long manifold runner. It's not like a high revving N/A engine which would have a peaky torque curve. Runner lengths quoted are manifold. Add another 100mm for length from trumpet to valve. This is what Dave Walker found with dyno testing various lengths: http://www.emeraldm3d.com/articles/emr-adj-length-intake/ Carl, the individual runners need to be separate. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
12th Dec, 2013 at 05:26:03pm
12th Dec, 2013 at 06:24:09pm
I guess it's all down to interpretation. To me, they imply negativity towards other people posting on the forum.
13th Dec, 2013 at 12:59:46pm
I think this links to a writeup on the Advanced Products Torque Ram which is what I was talking about...
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
13th Dec, 2013 at 02:23:25pm
On 13th Dec, 2013 Nial said:
I think this links to a writeup on the Advanced Products Torque Ram which is what I was talking about... http://www.theminiforum.co.uk/forums/topic...on-in-mtn-1982/ (Photos are blocked here so I can't check). Nial As far as I'm aware, the linked product works on a different principle. It uses the velocity of the air and the change of this into pressure to get a small "boost" effect going into the carb. Tuned length runners work on pressure wave reflections (downstream of the carb) to give a well timed increase in pressure. The issue with the stock manifold is that the timing is off so you get the trough not the peak (think of it as a wave). |
13th Dec, 2013 at 03:21:38pm
These replies are really really helpful, Thanks very much.
13th Dec, 2013 at 04:12:22pm
I guess it's all down to interpretation. To me, they imply negativity towards other people posting on the forum. Pfffft You only have to look in "Technical Chat" today to understand why people wont post. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
13th Dec, 2013 at 05:08:46pm
For the sensitive ones, I've changed my signature...
16th Dec, 2013 at 10:43:59am
On 13th Dec, 2013 Rod S said:
Sorry, OP, not your fault. Lol don't worry
Looking at the yeller book, p138ish, I might try and make something like the tubular Janspeed 1.5" bore
