Home > General Chat > Bead Breaker
dan187
Member #: 6724
Wootton Bassett
Anyone bought/ made themselves a bead breaker for changing the tyres on their mini themselves. I currently have 12" wheels but may change to 10's in the future so would want one suitable for both.
Dan
1275 EFi Turbo
1275grimsby
Member #: 10874
Grimsby
Ive changed mine by hand a couple of times, im on 12s and find the bead doesnt take much to make it go. Usually a bit of fairy liquid and educate it with a tyre lever and it goes.
mine: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=570945
PhilR
Member #: 10034
Birmingham
I was going to weld one up, but my bench vice works well enough that I never botherred
I bought one of those machine mart wheel changers, they have a bead breaker, works pretty well for changing most tyres, although I did do one set of tyres ( thanks Gary) that took 3 of us to get them on....
you can get tyre levers with PTFE buffers and rollers so you dont damage alloy rims, they work pretty well.
I've got one that I think is designed for tractor tyres. Wouldn't use it on a tyre I wanted to keep...
They were complete bastards.
This thread prompted me to get one of these:
http://www.ebay.co.uk/itm/New-Professional...=item4d1e91fb4d
Took about 1/2 hour to get the 1st 12" tyre of a wheel. Took about 5 minutes to do the second one.
The trick is lubrication *smiley*
Saves time taking them to a tyre shop.
Tomm
Member #: 1432
Kent
Never thought of making a bead breaker. My pikey ways suggested jacking a car up and dumping it down on the sidewall was suitable enough.
This thread has prompted me to revaluate.
yep, I got a pot of that white tyre paste and its well worth having, its actually like a load of little balls, which go to liquid under pressure.
that tyre machine looks the same as the one I have Paul,
here is the tyre lever I have, Ive had a look on titnter web and cant foind anything similar,
graemec
Member #: 1424
Carnforth, Lancs
Those levers are on ebay - about £50 I think
Edit...they've gone up:
http://www.ebay.co.uk/itm/manual-tyre-mach...=item27ef12532c
Edited by graemec on 25th Oct, 2014.
fucking well done, I searched for ages and couldnt find them!!
i have to say they do work damn well,
