| Home > Technical Chat > 1380 T2 or T3 | |||||||
7th Dec, 2005 at 10:20:01pm
Hi, VEMs Authorised Installer / Re-seller. K head kits now available!
809 Posts Member #: 224 Post Whore Katy TEXAS |
8th Dec, 2005 at 10:14:39am
Hello Bat,
8th Dec, 2005 at 11:38:34am
All this "automatic" subframe talk is nonsense IMO.
8th Dec, 2005 at 12:30:20pm
So basically you want to fit a turbo to your 1380 without cutting the bulkhead, and you want to run 10psi with a CR of 9.8:1.
Edited by wil_h on 8th Dec, 2005. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
8th Dec, 2005 at 01:29:27pm
On 07/12/2005 22:20:01 Bat said:
Hi, I'm currently running a N/A 1380 100lb-ft /120bhp. I want to go turbo, I'd like a T2 so I don't have to meddle with the bulkhead, or do I need a T3 for the extra engine capacity? I want to run about 9.8:1 and 10psi of boost and a T2 cam. I'm road going so I'm aiming for lots of low down torque. Discuss................
Cheers, Gavin. :) How about, instead of 'Discuss.............
You 'search' http://www.turbominis.co.uk/forums/index.php?p=search ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Been discussed a good few times; definately only a fe months ago aswell. On 17th Nov, 2014 Tom Fenton said:
8th Dec, 2005 at 07:05:54pm
Hi All,
8th Dec, 2005 at 08:32:48pm
T2 would spool up very fast on a 1380 with the c/r your planning on running, as you say hogster has been running similar c/r-boost with no problems. Does your mapped ignition system have a map sensor as to allow ignition retard as the boost comes in?? -MINI CLUBMAN 1380 TURBO- |
8th Dec, 2005 at 08:41:41pm
Hi Tone,
Edited by Bat on 8th Dec, 2005. VEMs Authorised Installer / Re-seller. K head kits now available!
8th Dec, 2005 at 08:50:47pm
Sounds good, i think you will be amazed at the torque you will get from this set up:) -MINI CLUBMAN 1380 TURBO- |
9th Dec, 2005 at 08:53:23am
I'm no ignition expert, but I thought that the minimum you need for a mappable ignition system is a MAP sensor and an RPM reading? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
9th Dec, 2005 at 10:59:06am
You can do mapped ignition on RPM only or RPM and TPS, but on a turbo that is useless and you might as well have a dizzy. http://www.twin-turbo.co.uk
12th Dec, 2005 at 01:09:11pm
Having used a T3 almost 10 years in a 1380 I can say that it is not bad, that 100 cc extra helps a lot. However, it is an "ancient" design and a T2 should give better results.
12th Dec, 2005 at 04:57:03pm
12th Dec, 2005 at 09:59:02pm
mine worked out with a 14.5 cc total volume of the piston to deck , 21.3 cc head and 3.4 cc for the head gasket which came out at 9.8 :1 cr.
13th Dec, 2005 at 07:32:13am
I have no first hand experience about Powermax pistons, I have bought some project engines with old flat top Powermax pistons (dating back to 80´s) that had most of the ring lands broken off the pistons. Maybe someone can comment on the pistons. At least the dish is good news. A lot depends on the rest of the assembly, are the pistons flush or down at the bore at TDC, what is the chamber size in the head etc...
13th Dec, 2005 at 11:12:47am
hi bat,
13th Dec, 2005 at 11:23:12am
Bat,
