Home > For Sale > 157 BHP, 170 lb ft TURBO ENGINE FOR SALE!! Forged JE Pistons etc
Metro Turbo
Member #: 437
Sunny Blackpool
Had a bad rear end crash last nite, spun 180 degrees and took a rear wheel clean off aswell as buckling the rear subframe, panel work damage etc, so my top spec Morspeed turbo challenge engine is now up for grabs.
Front of the car is immaculate, this photo of the engine was taken only on friday:
Ready to drop into your Mini / Metro. This has been recently set up at Mikeanics to give 157 BHP and 170 lb ft @ 15psi (with graphs). Just needs mappable ignition for 200BHP is you so desire.
Engine has covered 4000 miles since its build last year, and its spec is:
Block
Machined for a steel centre main strap, tapped for 11-stud cylinder head fixings (normally 9 studs), 5/16 sump, stress relieved block internals to help drain oil, bored and honed +020” to bring the capacity up from 1275cc to 1293cc. Block deck milled to accept JE pistons. New cam bearings, oilways and core plugs.
Cylinder Head
Morspeed Stage 4 head (29cc). Race valves 35.7mm inlet, 30.0mm exhaust, bronze guides, 180lb Springs, single top caps, tapped for 11 stud fixing. Fitted with 1.5 roller tip rockers.
Crankshaft
Re-ground, wedged, bladed, hardened, balanced and with fitted new VP2 bearings.
Con-rods and Pistons
JE Forged 18cc Turbo Pistons, lightened and polished con-rods. Bushed to accept small gudgeon pin. Fitted with ARP bolts.
Compression Ratio 8:1
Camshaft
Avonbar Racing T2 Turbo cam, steel duplex timing gears, high flow Turbo oil pump.
Gearbox
Straight cut, close ratio gearbox fitted with straight cut drop gears, new idler shims and primary shims. Ultra lightweight billet steel flywheel and billet steel backplate. AP bonded race clutch.
KAD Quickshift kit.
AP hydraulic clutch conversion.
Turbo
Garrett T3 Turbo modified by Owen Developments with their 360 Thrust bearing , fitted with 15psi actuator.
Braided oil feed pipe. Forge silicone oil return elbow.
Group A aluminium Forge dump valve.
Green Cotton cone air filter.
In car bleed valve.
Intercooler
Custom Forge Motorsport alloy intercooler, plumbed in using 50mm internal diameter blue silicone hoses.
Carburettor
HIF 44 Turbo Carb, rebuilt using Avonbar Racing high boost rebuild kit. High boost dash pot spring. Modified profile fuel needle.
Plenum chamber modified by Bailey Motorsport to accept dump valve, custom aluminium adaptor plate to allow intercooler fitment.
This is the car it is currently in. Can be heard/seen running.
Absolutely gutted to sell, I have spent £9000 on the car to date. All reciepts to go with the engine.
£offers please guys :(
Tim
89' Metro Turbo
157 BHP , 170 lb ft @ 15psi .... So far....
Mikeanics Rolling Road
WINNER OF RETRO CARS SHOW BEST 80's MODIFIED CAR
Please tell me this is a late april fools...*frown*
Sorry to hear about the Metro buddy it was very tidy.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
PM sent.
On 7th Nov, 2008 Nic said:
naeJ
m
Jackman
Member #: 984
Westhoughton, Bolton
Jeeze, what a shame :( Was a tidy car.
Manchester Minis
Brocky
Member #: 224
Katy TEXAS
Unlucky Dude:(
Ah gutting, Can't you plonk the engine in another Metty or /mini?
Seems a shame to let all the work go to waste! :(
Yeah, is the shell that bent?
a shame to split it.
Doodles_Mcpooh
Member #: 1252
Cornwall
Surely you can just find a new shell and drop the engine in?
mayoturbo
Member #: 1395
chepstow
pm'd
Metro Turbo
Member #: 437
Sunny Blackpool
I wish mate, i've been feeling sick all day about it :(
Tim
89' Metro Turbo
big commiserations tim , youd done a great job of building and prepping that car , i m sure your next effort will be as nice or nicer.
regards
JT
Member #: 637
Hertfordshire
that is a shame mate
hope you sort somthing out, and hope to see another turbo metro or mini turbo done by urself in the near future?
My build thread..
Kean
Member #: 341
aka T2clubby
South Staffs
Really sorry to hear this mate, your car was a gem.
Glad your ok yourself though.
giallofly
Member #: 164
The Stig..
Newport Pagnell
NO WAY!!!!
That car was something else....
Gutted for you..
JF.
Unfortunate mate. Was looking forward to seeing the car in the flesh. *frown*
AL
Member #: 1347
Croydon (South London)
Thats a real shame, and you just put those seats in too. Reshell out of the question then?
That's got to worth repairing or re shelling as it's a very tidy motor, that's obviously had a lot of time and money put into it.
Carl
Member #: 95
liverpool-on-sea
R.I.P's*frown**frown*
Metro Turbo
Member #: 437
Sunny Blackpool
I've managed to give it a real good impact at the rear drivers side corner, the subframe is bent and so are all of its mounting points.
I could re-shell it, but that would mean alot of personal time required to complete, and to be honest I've had the wind knocked out of my sails.
I'm just going to sell what I can and see what I can do with the proceeds.
Thanks for the nice comments guys :(
I will no doubt have another sleepless night tonight, I've got such a busy head.
Tim
89' Metro Turbo
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Really sorry to hear that! Was and still does look a tidy car! Real shame to see it split, have a while to think about perhaps you'll have a change of heart?:)
Well thats really bad luck,*frown*
Gutted for you.
shane
Member #: 1246
Lowestoft, Suffolk.
Sorry to hear that! Dont split it chap!!! You will only regret it when you get your enthusiasm back, go for a reshell, and look at this car as a learning curve and make the next one shinier and better! I mean shiney ALWAYS makes you feel better!.Shane.
How about getting it jigged?
OH SHIT!!!!
im gutted for you
dont sell, quickly go and buy that one on the bay that has had a light front-swap your bits onto it and jobs a goodun! http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:MEBI:IT&ih=017
do it do it do it
(balls im really sorry to hear this, but im sending you my enthusiasm to fix it over tinternet)
(amusingly i almost posted a pic to a link of a girl sat on the toilet here)
Edited by Nic on 3rd Apr, 2007.
