| Home > General Chat > Air filter to turbo | |||||||
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
24th Mar, 2008 at 10:22:08pm
What are you gents using to connect your air filters to the compressor housings, are there cheaper or better options than the "uncrushable" type that avonbar sell?
24th Mar, 2008 at 10:45:03pm
use the avonbar one no good skimping in this area shane
24th Mar, 2008 at 11:38:05pm
24th Mar, 2008 at 11:42:26pm
Its a little over 2 1/4" I think ? 9.85 @ 145mph
24th Mar, 2008 at 11:45:37pm
25th Mar, 2008 at 12:22:13am
i will be using a 60mm silicone elbow like so:
25th Mar, 2008 at 07:52:49am
25th Mar, 2008 at 08:22:50am
I use the hose, i think its cheaper from merlin.
25th Mar, 2008 at 08:56:49am
I've done something very similar to this, but found it to be a really tight squeeze. In the 13's at last!.. Just |
110 Posts Member #: 1657 Advanced Member wirral |
25th Mar, 2008 at 07:08:05pm
i managed to squeeze a 52mm silicone elbow on the end of the turbo On 15th of Apr, 2007 at 09:08pm Vegard said:
What the fuck is that on the rear of the car? One of the most stupid things I've ever seen. Rest looks nice. 10.5 psi no idea how many banannas |
25th Mar, 2008 at 07:40:58pm
25th Mar, 2008 at 07:43:59pm
from memory i think its around 60mm bat "Turbo's make torque, and torque makes fun"
25th Mar, 2008 at 07:47:00pm
63mm sticks in my head but i've got no turbo to measure it on |
25th Mar, 2008 at 07:49:06pm
My R5 T2 is 60mm OD, just measured it. Edited by Jay#2 on 25th Mar, 2008. On 7th Nov, 2008 Nic said:
25th Mar, 2008 at 08:45:26pm
25th Mar, 2008 at 09:44:01pm
25th Mar, 2008 at 10:22:58pm
Im after a section 60mm od to fit on a t2. Was looking the stuff from merlin, couldnt work out why the avon bar stuff is so much more?
25th Mar, 2008 at 10:28:35pm
25th Mar, 2008 at 10:30:51pm
you can buy an air filter that fits straight on to the turbo, that's another option. Best 1/4 mile 13.2 seconds @116 mph
25th Mar, 2008 at 11:02:31pm
25th Mar, 2008 at 11:10:03pm
On 25th Mar, 2008 Bat said:
Hi, I can get this in 60mm... http://www.merlinmotorsport.co.uk/AIR-DUCT...oduct_info.html I'm going to check it fits the T2 I've got at my w/shop. If it fits it should be around half that price... Cheers, Gavin :) |
809 Posts Member #: 224 Post Whore Katy TEXAS |
28th Mar, 2008 at 12:32:52pm
I did a similar thing to below and found the silicone hose sucked in quite a bit on boost, be careful of that as you will be choking the flow :)
On 25th Mar, 2008 theoneeyedlizard said:
I've done something very similar to this, but found it to be a really tight squeeze. Edited by Brocky on 28th Mar, 2008. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
28th Mar, 2008 at 01:43:20pm
ive got a silicone bend on mine, then i just use the normal (not high temp) brake ducting available from trident/merlin/etc...
28th Mar, 2008 at 01:43:43pm
If the filter was sucking in a lot, that surely points to a restrictive filter?
28th Mar, 2008 at 02:06:03pm
HHmmm, maybe. :) BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
