| Home > Help Needed / General Tech Chat > Hissing on boost, under load no power | |||||||
![]() 171 Posts Member #: 9928 Advanced Member Hartley, Kent |
2nd Dec, 2012 at 07:52:56pm
As stated above i seem to be getting a rather annoying hissing sound on boost and a lack of power whilst under load,
Low boosting for now. |
2nd Dec, 2012 at 08:06:05pm
Massive Boost leak?
In the 13's at last!.. Just |
2nd Dec, 2012 at 08:13:49pm
dump valve fucked.
2nd Dec, 2012 at 08:37:49pm
What Joe says.
2nd Dec, 2012 at 08:49:27pm
or dump valve full of petrol. On 11th Feb, 2015 robert said:
![]() 641 Posts Member #: 9937 Post Whore somewhereintheuniverse near selkirk scotland |
2nd Dec, 2012 at 09:21:25pm
dump valve or split in boost pipe thats not immediately noticable ,take the pipes off and check, and try a different dump valve give em hell |
2nd Dec, 2012 at 09:54:25pm
Check all hose joints, and as the gents. State,
2nd Dec, 2012 at 10:32:07pm
Okay guys, if it turns out to be the original dump valve or something so silly ill be so pissed,
2nd Dec, 2012 at 10:50:39pm
not necceseraly a fecked one will give the symptms you have give em hell |
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
3rd Dec, 2012 at 12:58:04am
my popper valve on the plenum was glued up by the previous owner. This broke for me and gave symptoms as you describe. was intermittent based on the load i was giving it. Boost gauge read full boost but it was clearly leaking. I glued it in place with some liquid metal. worked a treat. |
3rd Dec, 2012 at 05:35:01am
Sounds like this could be my best bet then, ill whip it out after work and look at sorting it out! :) Low boosting for now. |
389 Posts Member #: 9751 Senior Member Derbyshire |
3rd Dec, 2012 at 10:29:17am
On 3rd Dec, 2012 TurboMike1992 said:
ill whip it out after work :) HEHEHEHE |
3rd Dec, 2012 at 10:34:00am
Haha lol. Low boosting for now. |
3rd Dec, 2012 at 02:40:31pm
I had no heat sheild on mine and the holes on the plenum went through so had big boost leak 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
3rd Dec, 2012 at 04:07:54pm
On 3rd Dec, 2012 eden7842 said:
I had no heat sheild on mine and the holes on the plenum went through so had big boost leak ![]() I would have assumed these would be blind holes. Interesting thing to check regardless. On 17th Nov, 2014 Tom Fenton said:
3rd Dec, 2012 at 06:47:50pm
Just checked my old plenum and they appear to be blind holes,
3rd Dec, 2012 at 06:49:55pm
3rd Dec, 2012 at 07:22:08pm
Mines the same and its fine at 25psi 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
3rd Dec, 2012 at 08:03:54pm
Thing is tho when i re clamp it it runs nice for a bit then slowly comes back, repeat the process the same happens.
3rd Dec, 2012 at 09:27:41pm
Ideally, you need someone to run a bead of weld around to make a retaining lip, but if you put three self tappers in around the edge and then clamp the hose behind their heads I would be very surprised if it came off again. |
3rd Dec, 2012 at 10:12:00pm
Having doubts to weather this is actually the problem now,
4th Dec, 2012 at 01:01:21am
get some soapy water on your pipe if you don't want to take it apart but to glue up the plenum is an easy 30 min job. You may as well just try it. Edited by dan187 on 4th Dec, 2012. |
4th Dec, 2012 at 07:37:58am
Block off the compressor housing on the turbo so it won't leak air. Adapt a fitting so the airline can be connected to theengine. Full with air to the desired pressure and have a look to see where your leaks are. Works a treat. You will be surprised to see what leaks! |
4th Dec, 2012 at 09:29:49am
Oh my god, why did i not even think that! *slaps head*
6th Dec, 2012 at 08:42:21pm
Did a pressure test, found a hose with a split, however tried sleeving the split, no joy still 'pssshhhh' and no power, just went to the extent of going back non intercooled as the standard setup would be, and hey presto, no joy, i really cannot work this out its been ages now and am really getting fed up with it. Low boosting for now. |
