| Home > Help Needed / General Tech Chat > more brake problems | |||||||
23rd Sep, 2006 at 08:55:50pm
swapped my brakes over today, the car is a 73 and running a single line master cylinder with the valve thing on the rear subby. stock drums at the back but early metro 4 pots with solid discs up front.
23rd Sep, 2006 at 08:59:24pm
Well - the answer lies in that rear corner...
23rd Sep, 2006 at 09:07:23pm
well i took it round the block and the brakes are shite, pedal hits the deck and the car hardly slows down. there is some resistance in the pedal but i reckon there's a load of air trapped somewhere, more than likely in that rear corner. Lets hope i get it sorted in the morning, oh the joy of the circlip on the cylinder On 20th Oct, 2015 Tom Fenton said:
![]() 608 Posts Member #: 1106 Post Whore Hungerford, Berks |
23rd Sep, 2006 at 09:07:34pm
Being stupid, we spent an age trying to bleed ours after fitting 4 pot calipers on the front and replacing rear components, then the old man realised he had not adjusted the rear shoes. once done we were able to bleed it properly. ’77 Clubman build thread
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
23rd Sep, 2006 at 09:54:06pm
is the rear corner brake staying on after you release the pedal, if so your problem lies in the flexi if not i am no use "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
24th Sep, 2006 at 06:10:11am
Tom's piss easy method for securing rear brake cylinder circlip.....
24th Sep, 2006 at 01:47:18pm
26th Sep, 2006 at 05:06:19pm
found another problem with the brakes last night, bled them all and re-adjusted and it was still a bit spongey. the fecking front flexi hose is bulging when you press the pedal.
26th Sep, 2006 at 11:44:07pm
The thingy on the back subframe ! If you unscrew the end of it inside is a spring and plunger,if you drill and tap it and bung a bolt in it to compress the spring it works as a adjustable thingy so you can turn the rear braking force down
Edited by Dangerous on 26th Sep, 2006.
27th Sep, 2006 at 12:41:03pm
change the front hose as this will fail you and is compounding the issue budd, check the other one as well
27th Sep, 2006 at 02:15:30pm
got a pair of braided front hoses sat in the car waiting to be fitted tonight hopefully if the weather holds off.
28th Sep, 2006 at 11:47:32pm
went to fit the new braided hoses tonight and its all gone to piss again.
29th Sep, 2006 at 01:38:31am
On 28/09/2006 23:47:32 bud666 said:
Anyone else ever had trouble fitting the braided hoses to a 90's car? It seems like one thing after another at the minute, not impressed No, never had a problem at all. In fact, I find working on old minis a breeze, I never struggle with siezed bolts, stuck flywheels, rotten sills, fucked radius arms, or anything like that. I'd hate to have a modern car where you can plug in a computer and have it tell you what is wrong, and then fix itself with a single press of a magic button. On 17th Nov, 2014 Tom Fenton said:
29th Sep, 2006 at 08:59:06pm
Edited by Bat on 29th Sep, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
