Home > Help Needed / General Tech Chat > Someone helpful :)
Markie_D
Member #: 1660
Formally Mini_Uk
London
Hi all,
This is me car.
1275 MG Metro Turbo.
Cam belt driven.
Unleaded cylinder head with bronze valve guides,
10 row oil cooler. and maniflow turbo single 2" box system.
Ive just orderd a T-hose for the dump valve i want to get.
Im still learning stuff, did a search, but still not 100% sure what i do.
Right im going to get a dump valve,
Worked out how to fit it.
So which 1 would you say i get. or would the cheaper one be ok.
http://www.nicenewcar.co.uk/parts/part-2079.html
http://www.xfactormotorsport.co.uk/viewprod.asp?prod_id=284
Then i want to up the boost to about 8 (psi)
So i Need.
(1) 8 (psi) Needle
(2) a bleed valve, Can someone show me what one i get.
And still not 100% how you fit and boost it up. is there something that has to be done to the fuel also ?
And what else would you say i need to get and do to get this all up and running.
Be great if someone could inlighten me.
Sorry if this has be asked before. but i just need bit more input.
Be more then greatful if someone could help.
Regard's
Shit Happen's
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Most people on here use a single piston Baileys or a diaphragm type from Forge. After doing a lot of research on this, Baileys are of the piston variety of DV and some people have reported that the seals in this DV swell with fuel contamination and this results in the piston sticking open. The forge type are diaphragm type DVs and these don't have this prob but instead the diaphragms can split. However you can get uprated diaphragms for them. I don't think there is any benifit of a twin piston type on an A series, they are for cars with air flow meters (??).
The DV in the first link looks like this one...
http://cgi.ebay.co.uk/TWIN-PISTON-DUMP-VAL...1QQcmdZViewItem
Might save you a few £££s.
Edited by Jay#2 on 14th Apr, 2007.
On 7th Nov, 2008 Nic said:
naeJ
m
Markie_D
Member #: 1660
Formally Mini_Uk
London
So should i not bid for the one you have up on the link, as thats a twin ?
Shit Happen's
Jay#2
Member #: 648
Theres heaps on ebay if you don't want a twin piston...
http://cgi.ebay.co.uk/GROUP-A-FORGE-DUMP-V...1QQcmdZViewItem
http://cgi.ebay.co.uk/forge-piston-dump-va...1QQcmdZViewItem
http://cgi.ebay.co.uk/forge-dump-valve_W0Q...1QQcmdZViewItem
http://cgi.ebay.co.uk/Bailey-Dump-Valve-fr...1QQcmdZViewItem
http://cgi.ebay.co.uk/Bailey-Motorsport-Pi...1QQcmdZViewItem
naeJ
m
Markie_D
Member #: 1660
Formally Mini_Uk
London
Would that one do the job though http://cgi.ebay.co.uk/TWIN-PISTON-DUMP-VAL...1QQcmdZViewItem
As it looks cheap enough ..
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
I won it for £26 :)
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
well £28.11p all in all :)
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
So now i need a bleed valve.
What sort of valve am i looking for. ?
Shit Happen's
Bin the ECU then you'll run 7psi, couple of turns on the acutuator and it'll be 8psi. It'll perform better than with a bleed valve too.
Get it set up on a rolling road, that's essential.
Edited by Bat on 14th Apr, 2007.
Markie_D
Member #: 1660
Formally Mini_Uk
London
How do i find the ECU.
Where the arow is in the picture,
http://allyoucanupload.webshots.com/v/2005210676811873359
It's blocked.
Doe's this mean there is no ECU ?
Shit Happen's
Not the one in the picture.
You need to follow the pipe from the actuator to the turbo compressor housing and fit a Manual Boost Controller (MBC) Ebay is the best bet
Sorry my mistake, the standard actuator only runs 4 psi.
With the MBC you'll be able to set it to 8psi.
Set it up on the rollers, think about putting an intercooler in.
Do a search, it works well on this site, try ecu or boost or mbc or bleed etc.
Ric
Member #: 36
Basingstoke
Bat is right. Go to the other side of the carb and take a pic, we'll show you where you need to fit the bleed valve/mbc.
Ric
Member #: 36
Basingstoke
oh yeah, when you plumb in your DV you need to think about where you are going to get a vacuum take off to open it with...
Markie_D
Member #: 1660
Formally Mini_Uk
London
Well i cant do that now as ive taken the carb off. and in bit's, as ill be rebuilding it with a rebuild kit.
But i found this picture of the net if this should help ?mabe if you dont mind, you could draw onto the picture and tell me where i fit it etc. that be great.
http://allyoucanupload.webshots.com/v/2005938573859686617
And in the link below, is that the (MBC) i need. is the bleed valve the same as a (MBC)
http://cgi.ebay.co.uk/Manual-Boost-Control...1QQcmdZViewItem
As for a vacum take off. the car has one of these fitted, boost gauge.
To be honnest i dont really understand what it tell's me as such.. but could i came of this ?
http://allyoucanupload.webshots.com/v/2000018904971931507
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
Shit Happen's
That looks like a bleed valve to me, despite the description.
The engine picture's not much use other than you can see the actuator. Try this link from the "How to" section of the site
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=108
Unfortunately someone has stolen the pics, Iain?
giallofly
Member #: 164
The Stig..
Newport Pagnell
Reet,
See that "loop" that runs from the actuator to the compressor?
Well, the bleed valve goes between that, ie, the actutor if fool it is getting less boost where as the engine is getting more therefore more power.
It is worth making that loop longer so it is easier to get to and make sure it is out of harms way, ie not too close to the exhaust manifold etc.
If you want it in car you can put a T piece in that loop and run into the cabin, the bottom outlet on that ebay valve is the outlet, that can just go atmosphere. If you run it in car just block one side of the valve.
Hope that helps.
JF.
Markie_D
Member #: 1660
Formally Mini_Uk
London
Can someone show me some pic's please, of what they have done.. and how do i know if i still have a ECU. i brought the car of someone, so im still not 100% on stuff :)
if there a part on the site that shows me stuff, ive searched not not really found that.. thanks for your support
Shit Happen's
giallofly
Member #: 164
The Stig..
Newport Pagnell
Markie_D
Member #: 1660
Formally Mini_Uk
London
So the pipe at the bottom right, where's that going, to the solenoid ?
And is this what i want ?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...atchlink:top:uk
Shit Happen's
Jay#2
Member #: 648
If you want it mounted in the car so it can be adjusted on the fly then try this...
http://cgi.ebay.co.uk/Turbo-bleed-boost-va...1QQcmdZViewItem
If you want one as in the pic above (ie fitted and adjusted from the engine bay) then...
http://cgi.ebay.co.uk/Brass-lockable-2-por...VQQcmdZViewItem
naeJ
m
Markie_D
Member #: 1660
Formally Mini_Uk
London
Ok cool. so say i have it in my car, can i have it on the dash board.and if so, when i turn the boost up, could i get something in the dash to tell me what boost im running at. whats the fly ? lol i just got a haynes, so im getting the idea of it now.as i didnt know what the part's were that were said in what were talking about.. so was lost. getting there though thanks to u guy's.
plus is this the solenoid i have to get rid of ? as this isn't on the regulator ?
Thanks guy's
http://allyoucanupload.webshots.com/v/2004115896831094163
Shit Happen's
giallofly
Member #: 164
The Stig..
Newport Pagnell
If you want more boost just pull the wires off the solonoid, it does make a difference, I have owned 4 Mtero turbos.
It will go bang eventually.
Have fun.....
JF.
Markie_D
Member #: 1660
Formally Mini_Uk
London
What will go bang eventually, the engine?
So that not a good idea then..
Shit Happen's
Jay#2
Member #: 648
Yes you can mount the first bleed valve in the link I posted above on the dash and anywhere handy in the car. On the fly as in while your in the car. With it mounted on the dash say, you can fiddle about with it, if it's mounted in the engine bay then you can only tweek when your out of the car. A boost gauge will tell you what boost your running. Say for example this one from our old friend ebay...
http://cgi.ebay.co.uk/New-Autogauge-52mm-W...1QQcmdZViewItem
But with all that said if your planning on running with the solenoid disconected you'll get 7 psi without a bleed valve as you actuator is set for 7 psi!
naeJ
m
