Home > General Chat > that 'wheel speed/rpm/gears graph' thread
Im looking for that thread where people were dicussing different f/ds and posting up graphs showing wheel speeds in differnet gears etc
Trying to determine which f/d will give me the right 2nd/3rd shift spot.
Can someone point me in the right direction?
Joe
Edited by joeybaby83 on 3rd Jun, 2007.
I've got a link to an online calculator, just tried it and it's dead :(
johnK
Member #: 690
Norfolk
Joey send me your info and I'll do the "gear cascade" for you. need torque curve gear ratios/ tyre and final drive(s)
cheers
If Carling made Mini engines
ha john, you must be having a laugh!
i have no torque curve, infact i havent any torque full stop! (yet)
thanks though, one day when i have a mini that runs ill take you up on the offer :)
Nick
Member #: 154
Midlands
http://www.minifinity.com/index.php?name=U...req=getit&lid=4
give that a try dude, quite useful.
this thread? http://www.turbominis.co.uk/forums/index.php?p=vt&tid=7415
Brocky
Member #: 224
Katy TEXAS
Joey,
I think this might be the one ?
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=126550
Also John did this for me, the gears are run from 2000 rpm to 7000 rpm, I guessed the torque curve, key points - 120 lb/ft at 3000rpm, max torque 135 @5500, max bhp 140 @5500, holding good torque to 7000 were I've used 90 lb/ft. reasonable for a well developed turbo motor? the figures in the chart are at the wheels - a 20% drop from flywheel figs was used. based on the torque curve you can see the additional accelerative force avaialble if you used a 3.44 in place of a 3.2 for not a lot of drop in speed in the gears. If someone has a "real" torque curve of around 140bhp we could input this to compare diff ratios more accurately
Hope this helps
Brocky
Edited by Brocky on 4th Jun, 2007.
id have thoughut that if pk bhp is 55 then pk torque would be more 4 to 45 ish ?
