| Home > Help Needed / General Tech Chat > clutch slip | |||||||
![]() 124 Posts Member #: 1428 Advanced Member Cleveleys |
14th Oct, 2007 at 07:08:00pm
I have fitted the mini spares turbo clutch http://www.minispares.com/Product.aspx?pid=32713
998 turbo in progress.... DONE..........KNACKERED LOL |
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
14th Oct, 2007 at 07:13:09pm
What sort of power are you running? |
14th Oct, 2007 at 07:41:44pm
81bhp at 8psi, its started slipping with new clutch at 8psi when before it only slipped when i turned up boost to 14psi
14th Oct, 2007 at 07:42:44pm
think new ones vary, only way is to see how thick the spring is inside the diapraghm. |
14th Oct, 2007 at 07:52:20pm
14th Oct, 2007 at 08:11:36pm
hahaha classic gavin . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
15th Oct, 2007 at 12:02:11am
I'm still learning about turbos so excuse my stupidity.
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
15th Oct, 2007 at 12:23:54am
On 14th of Oct, 2007 at 07:52pm Bat said:
Hi, You won't get a Verto clutch that can handle 14psi, unless you make a Robert special. As Iain said you'll have to measure it. Cheers, Gavin :) Whats a Robert special Gavin ? What did he do to his verto setup ? Cheers.. Shit Happen's |
15th Oct, 2007 at 06:54:47am
just change to pre verto job done with a grey diaphram, these verto turbo plates are pretty poor, always looking for them bigger bunches of bannanas |
15th Oct, 2007 at 08:40:45am
On 15th of Oct, 2007 at 12:02am chappers said:
I'm still learning about turbos so excuse my stupidity. But why cant a clutch handle the power if say 81 bhp is gained from 8psi and say 100bhp is gained from 14psi, surely some 1275s can chuck out 100 bhp even on 6psi of boost. I thought it depended on the power? So i really need to get a pre verto clutch set up? It's all about torque, not power. The maximum torque that that clutch can handle is about 90 lbft. Your turbo engine is probably putting out around 100 lbft. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
15th Oct, 2007 at 10:25:22am
15th Oct, 2007 at 11:29:13am
Does this mean that my clutch is an upgraded item? It was on the car when I got it and I've not had it apart yet.
In the 13's at last!.. Just |
15th Oct, 2007 at 11:31:34am
This should help.
15th Oct, 2007 at 11:55:21am
or there is stu gurr's uprated verto is there not?
15th Oct, 2007 at 12:10:29pm
Uprated verto not really up to the job from what I've seen, ask Benross.
15th Oct, 2007 at 12:25:50pm
i had the stuart gurrs uprated one
15th Oct, 2007 at 01:15:43pm
ah but for 100curly wurlys and bananas it would be. just thinking if he's not going up in power with it being a 998 it would save the change to the non-verto and be kinder on thrusts. |
15th Oct, 2007 at 10:38:08pm
Right i have decided to go down the pre verto route.
15th Oct, 2007 at 10:47:20pm
On 15th of Oct, 2007 at 10:38pm chappers said:
can a verto slave and arm be used with a pre-verto clutch set up? In short, NO.
15th Oct, 2007 at 10:54:16pm
The Janspeed turbo conversion used a turbo over the clutch and as a result there was no space for the slave cylinder.
15th Oct, 2007 at 11:05:57pm
Yes if you search "janspeed turbo" on here you will get to see the bracket and pushrod, the slave is not fitted but I am sure you will get the idea.
16th Oct, 2007 at 01:26:03am
Echo! toms and danboy thoughts
16th Oct, 2007 at 03:31:00pm
Right i literally had a dream about the problem last night, yes i even dream about minis!!! LOL
16th Oct, 2007 at 04:39:38pm
Please excuse the crudity of the model, but you get the jist.
