| Home > Help Needed / General Tech Chat > Ignition help needed please! | |||||||
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
7th Jan, 2008 at 11:20:37pm
Right guys, we've been playing about with the car tonight, just trying to get a few jobs sorted. Anyways, we had the car running really nice, then it cut out. I tried to start it again and one of the lads noticed a spark coming from near the coil. It turned out that the metal casing on the choke cable, was touching a bracket on the coil and was causing a spark - I find this odd myself.
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
7th Jan, 2008 at 11:30:35pm
Sounds like you have one of the early style electronic setups with the ignition module mounted seperately. These ignition modules are available cheaply new, do a search on the forum as someone posted a web source to get them at a good price.
7th Jan, 2008 at 11:39:50pm
I can't see anything in the Haynes relating to the Ducellier dizzy - although I am going off a Mini manual, and not an MG Metro Turbo manual as I don't have one.
7th Jan, 2008 at 11:49:15pm
Buy a Metro haynes manual as a first step.
7th Jan, 2008 at 11:55:17pm
Will do.
8th Jan, 2008 at 12:16:45am
8th Jan, 2008 at 12:27:18am
What sort of wiring are we talking about? What extra is there on the Lucas that isn't on the Ducellier?
8th Jan, 2008 at 08:23:51am
For the price of an Avonbar dizzy your could nearly get a Megajolt set up. It is superior to any dizzy but I guess it depends if you just want the car running without any fuss or want the best. On 7th Nov, 2008 Nic said:
8th Jan, 2008 at 08:45:50am
For now I just need the car running and by this weekend for the Wirral to Llandudno run. I will probably be going Megajolt when I build the new engine, but for now I just want to get it running again.
8th Jan, 2008 at 09:35:34am
Edited by Bat on 8th Jan, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
8th Jan, 2008 at 09:42:10am
On 8th of Jan, 2008 at 09:35am Bat said:
EDIT: Before you go buying things check you have a good engine earth. Stick a jump lead from the battery negative to the egnine block then try to start it.... Oh my god, I can't believe I didn't even think of that! Why is it always the simplest things that you forget about?!?! We could have disturbed the engine earth when arsing about in the engine bay moving things about. I'll try that when I get home this evening - maybe the earths need re-doing. Will still get a coil just incase as I can take it straight back tomorrow if I don't need it. On 15th Jul, 2009 fastcarl said:
8th Jan, 2008 at 09:55:43am
8th Jan, 2008 at 10:08:33am
On 8th of Jan, 2008 at 09:55am Bat said:
Hi, The fact you've getting sparks off the choke cable is the clue
Cheers, Gavin :) Well we got the sparks off the choke cable before we moved anything in the engine bay. So maybe its been dodgy since I picked the car up and has finally gone altogether. I shall try the jump lead trick and check the earth strap etc.... and maybe add some more earths - you can never have too many earths!!! On 15th Jul, 2009 fastcarl said:
8th Jan, 2008 at 10:16:47am
8th Jan, 2008 at 01:09:01pm
I don't think so, because I've had the car running without the choke cable touching the coil, it was just when it touched the bracket that the ignition module is sat on (which is on the coil) we got a spark and the car cut out. Thats what makes me think either the coil or the ignition module has blown.
8th Jan, 2008 at 01:36:49pm
Right, just doing some digging, and this is the dizzy cap thats on my car:
8th Jan, 2008 at 02:27:22pm
I thought you said that it had points?
Edited by theoneeyedlizard on 8th Jan, 2008. In the 13's at last!.. Just |
8th Jan, 2008 at 02:58:05pm
Thats what I was told when I picked the car up! This gets stranger and stranger.
8th Jan, 2008 at 03:55:06pm
On 7th of Jan, 2008 at 11:30pm Tom Fenton said:
Sounds like you have one of the early style electronic setups with the ignition module mounted seperately. YES.
8th Jan, 2008 at 04:29:32pm
Right, now to go to my autofactors and give them the actual part number that they couldn't find for themselves! They are an Intermotor stockist, so you'd have thought they could have found that!!!
8th Jan, 2008 at 04:39:43pm
These ignition modules are available cheaply new, do a search on the forum as someone posted a web source to get them at a good price. I typed 'module' into the search and it brought this up: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=182463 "Turbo's make torque, and torque makes fun"
8th Jan, 2008 at 04:40:19pm
and this:
8th Jan, 2008 at 04:42:27pm
and this:
8th Jan, 2008 at 04:43:14pm
so you have a few starting points now, good luck "Turbo's make torque, and torque makes fun"
8th Jan, 2008 at 10:56:14pm
All sorted now guys. My mate found a spare later type dizzy, so we ditched all the old crap, replaced the coil and tidied all the wiring up and now she's running again.
