Home > Help Needed / General Tech Chat > Non verto slave cylinder on a verto clutch
Neil8p
Member #: 65
South Yorkshire
Found this
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=186634
and this
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2105
As I have no servo so there is room for the bleed screw, I'd like to know if can I use a non verto slave cylinder on a verto clutch setup.
Thanks
yes
yep bores are the same size.
Concerning this, is the rod in the slave the same length between Verto and not as well?
The thing is. I just rebuilt a gearbox, that the local Rover dealer fitted to a Mini. It still crunches when gearing fast. As we all know, sometimes it's necessary to use a longer slave rod in Pre Verto Minis. Could this be necessary on a Verto clutch? Has anyone experienced this?
I haven't tried bleeding the clutch as of yet, but I'm clutching at at straws on this, ( Pun intended)
New synchro rings etc..
On the Verto, the throw out stop should be adjusted to give 6.5mm clearance between the nut and the wok, with the release bearing in contact with the thrust sleave (basicaly pull the arm away from the engine till it takes up the slack)
If the throwout stop never touches the wok after adjustment, there is hydraulic problems. If it does touch then its the gearbox?
Edit: The adjustment only ever applies to a new un worn clutch, because, as the clutch wears the measured gap becomes larger to achive the same throw out*oh well*
Edited by Sprocket on 17th Jul, 2008.
crazy1275
Member #: 1634
i have pre-verto setup on a verto clutch - i made the push rod part (that go-s into the slave)adjustable to give more throw, works fine.... but is not perfect
would prefet to go all verto gear.... then again my clutch isnt holding up to well
