Home > Help Needed / General Tech Chat > clutch sloping
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
hello
I have a normal verto cluch witch is slipping if I turn the boost above 8psi if I change this to a 4 paddle one from deamon tweeks will this sort it out, thanks
The verto should be fine up to about 10psi.
Mine was not slipping at 15psi.
alandavies215
Member #: 1844
thanks for the reply, clutch has only done about 25 miles so don't understand it
alandavies215
Member #: 1844
sorry about heading should be clutch slipping
Is it a turbo Verto clutch that you fitted?
Ben H
Member #: 184
Melton Mowbray, Pie Country
Have you read this thread, might be of some use?
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=201746
http://www.twin-turbo.co.uk
Yep, sound like the same problem I had. The new springs being supplied are not upto the job.
alandavies215
Member #: 1844
no its a normal asparated one
