| Home > Help Needed / General Tech Chat > Part throttle lean off pipe | |||||||
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
13th Apr, 2008 at 05:54:51pm
What's the general feeling on this? Mine is still connected at the moment, but i know a lot of people block it off. Is there any advantage either way?
13th Apr, 2008 at 07:03:58pm
cant see any reason for blocking it off ? 9.85 @ 145mph
13th Apr, 2008 at 07:39:08pm
Mine would lean out when going from a steady cruise to full throttle when it was connected.
In the 13's at last!.. Just |
13th Apr, 2008 at 07:40:33pm
leave it in there if the fuelings ok it means cruise MPG
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
13th Apr, 2008 at 08:30:33pm
which pipe is this then?? On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
13th Apr, 2008 at 10:58:35pm
mines on |
13th Apr, 2008 at 11:05:10pm
I did some testing on this.
13th Apr, 2008 at 11:10:24pm
13th Apr, 2008 at 11:13:45pm
I had trouble getting the right fuelling with it connected, so mines blocked. |
13th Apr, 2008 at 11:16:14pm
On 13th Apr, 2008 Bat said:
Hi, I'd be tempted to polish the needle with it blocked off, then put it back on after. Only if you can monitor the mixture though! Cheers, Gavin :) There's quite a big difference... when I said a little I was not strictly trutheful!! The leanoff pipe does not affect 3/4 -full throttle but does change the rest. I ended up with quite different needles. but hey, I only tried it once.. Edited by Turbo Tel on 13th Apr, 2008. website:- http://www.terryhunt.co.uk
13th Apr, 2008 at 11:24:48pm
14th Apr, 2008 at 08:04:33am
im still unsure of this pipe ,what do you connect it too?
14th Apr, 2008 at 09:17:11am
14th Apr, 2008 at 09:17:54am
It is the external rubber pipe on a proper turbo SU that loops round from one stub to another on the carb itself, only about 5" o/a length.
14th Apr, 2008 at 09:37:50am
cheers gary/tom!
14th Apr, 2008 at 01:37:37pm
I had most luck running it through a solenoid - closing it when i wanted to plant the throttle, and opening it other times. Was a PITA though, so off it came. On 17th Nov, 2014 Tom Fenton said:
14th Apr, 2008 at 01:52:22pm
Could there be some cleverness possible here, with a MJ output setup to close this solenoid at high load points determined by the MAP sensor, and then open it again at cruise points again determined by the MAP sensor?
14th Apr, 2008 at 01:54:58pm
indeed you could tom
14th Apr, 2008 at 02:03:33pm
I did think about this Tom, but ICBA, so the whole lot came off... On 17th Nov, 2014 Tom Fenton said:
14th Apr, 2008 at 02:21:12pm
Sounds like a good idea. In the 13's at last!.. Just |
2nd Sep, 2008 at 10:56:23pm
Can these be retro fitted to NA HIF carbs? or is it something that only works under boost? Isambard Kingdom Brunel said:
2nd Sep, 2008 at 11:06:48pm
Can't see why not, because even on a turbo your generally running vacuum on cruise and not boost.
Edited by matty on 2nd Sep, 2008. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
3rd Sep, 2008 at 12:03:06am
3rd Sep, 2008 at 11:18:04am
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=9974
Edited by robert on 3rd Sep, 2008. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
4th Sep, 2008 at 03:16:40am
I have changed my mind on this since my post further up.
