| Home > General Chat > Intercooler hoses... has anyone done this? | |||||||
36 Posts Member #: 1611 Member Blackpool |
30th May, 2008 at 12:22:13am
Has anyone saved money by welding pipes together then just using samco hoses at the ends for the connections to the intercooler etc..? If so do you have pics?
Edited by Ro8bieg on 30th May, 2008. |
30th May, 2008 at 12:58:41am
got no pics to hand, but yes. I used large cooper piping with bends, it was a cheap way of doing it as we had them. Best 1/4 mile 13.2 seconds @116 mph
30th May, 2008 at 01:04:44am
Ohh okay, in the intercooler pipes, is it high pressures or just freeflowing air? |
30th May, 2008 at 01:14:01am
both Best 1/4 mile 13.2 seconds @116 mph
30th May, 2008 at 01:14:31am
its not high pressure under 30 psi in most cases! ............... if you have the time and and skills go for the pipe options
30th May, 2008 at 09:43:55am
On 30th May, 2008 BENROSS said:
its not high pressure under 30 psi in most cases! ............... if you have the time and and skills go for the pipe options Ahh i think I will then, does anyone have any pics of any that have been done? Edited by Ro8bieg on 30th May, 2008. |
30th May, 2008 at 11:50:41am
Heres mine.
30th May, 2008 at 12:06:57pm
really really old one of my old car.
108 Posts Member #: 505 Advanced Member Stockton-on-Tees |
30th May, 2008 at 12:48:30pm
I got one of the local 'custom' exhaust places to bend me some pipes and weld them together.
271 Posts Member #: 1844 Senior Member BURNTWOOD, staffordshire |
30th May, 2008 at 04:27:33pm
hello if u have an email address will send u a picture of mine carnt upload pictures daughter has gone away and carnt figger it out myself |
![]() 514 Posts Member #: 2169 Post Whore Malta (Ex. Scotland) |
30th May, 2008 at 04:32:57pm
But won't the spatter from the weld interfere with smooth airflow?
Warning:Stig in Training
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
30th May, 2008 at 04:59:49pm
My welding is shocking and silicone pipes from ebay were quite cheap so it was an easy choice for me.
30th May, 2008 at 06:56:01pm
30th May, 2008 at 06:59:32pm
Here's a good example:
On 14th Apr, 2008 turbominivanman said:
A few pics of my RST i/c install. The i/c shroud, brackets and pipework are all home made. The air intake to the i/c is via three holes in the RH side of the bonnet. The shroud stops the air from escaping into the engine bay as it enters through the bonnet. All of it goes through the i/c to improve its effectiveness. Hope the pics help. Richard.
And this one is equally as good: On 8th Aug, 2004 Justin said:
Just finished fitting my intercooler.Fabricated the pipes from some old XJR1200 motorcycle downpipes as they were the perfect inside diameter. The pictures are of the pipes,the modified plenum pipe and test fit on my spare engine and the final fit on the car itself.Just need to get some jubliee clips tomorrow so I can test it. There is about 5mm spare inside between the top of the intercooler and the bonnet when it is closed.
Edited by Rob H on 30th May, 2008. Isambard Kingdom Brunel said:
30th May, 2008 at 07:11:47pm
theres mine , the piece over the rocker box is made of about 5 pieces ,and the other one from about 3... i think .
30th May, 2008 at 10:34:17pm
just make sure you try and keep the bends as smooth as possible. Thanks for the quick replies. This is what I was looking for! can you use filler on these just to smooth off the edges or do they flex to much? |
30th May, 2008 at 11:26:47pm
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
30th May, 2008 at 11:57:15pm
Why would you want to use filler? surely a decent weld with good penitration can me flatted off with a sanding disk on a grinder?
31st May, 2008 at 01:11:54am
31st May, 2008 at 09:26:12am
Lol, love the honesty Nick.
31st May, 2008 at 01:46:28pm
lol kk, instead of chopping and welding could I cut 3/4 of the way through the tube then bend it then weld and keep doing this to make a smooth bend? |
31st May, 2008 at 05:58:03pm
1st Jun, 2008 at 08:30:17am
What thickness pipe should I use? Its for a renault 5 IC, ill measure the diameter but what thickness should the walls be? |
