| Home > Help Needed / General Tech Chat > Tapping cylinder head! | |||||||
24th Jun, 2008 at 03:36:50pm
24th Jun, 2008 at 05:09:00pm
yes use a 6.8 mm drill and use a M8 tap and open the holes out on the plate
24th Jun, 2008 at 05:12:17pm
I'd maybe try a 6.5mm drill, remember cast iron is soft as sh1t!
24th Jun, 2008 at 05:37:44pm
Ok i'll try it cheers lads.
24th Jun, 2008 at 06:28:17pm
no need to take the head off, just use a hand drill
Edited by BENROSS on 24th Jun, 2008.
24th Jun, 2008 at 06:31:14pm
M6 helicoil kit no good for this? is the cast too soft? |
24th Jun, 2008 at 06:44:54pm
24th Jun, 2008 at 06:48:16pm
The original thread would have been 1/4" UNF - that's why it stripped. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
628 Posts Member #: 1064 Formally Whyte_ben Horndean, Hampshire |
24th Jun, 2008 at 06:48:27pm
I rekon its cheaper and probably easier just to drill them out and re-tap them 8mm like the chaps say.
Edited by Ben. on 24th Jun, 2008.
24th Jun, 2008 at 07:39:33pm
Just looked and we have s**t loads of 1/4 UNF helicoils, so you can use them if you want.
24th Jun, 2008 at 08:45:06pm
On 24th Jun, 2008 Paul S said:
The original thread would have been 1/4" UNF - that's why it stripped. I put the blanking plate back on with the bolts that came out of it originally and these are what initially stripped it! I didnt overtighten and they weren't cross threaded! e I say the holes are M6 I mean just 6mm. The second bolts where new stainless bolts which I ran down and these where 1/4" ones. Cheers Ben, I'll see how it holds up for the MOT and bring it round to use your taps/hellicoils. Ta Edited by richminiturbo. on 24th Jun, 2008. |
25th Jun, 2008 at 07:31:42am
Tapping 8mm is fucking sacrilidge. If you are to tap it a bigger diameter be so smart to use 5/16UNF. I hat those mm/imperial mismatchers wankers! On 13th Jul, 2012 Ben H said:
25th Jun, 2008 at 07:35:36am
On 25th Jun, 2008 Vegard said:
Tapping 8mm is fucking sacrilidge. If you are to tap a bigger diameter be so smart to use 5/16UNF. I hat those mm/imperial mismatchers wankers! Ok, thanks for your input. Once again youve been a great help. Edited by Ben. on 25th Jun, 2008.
25th Jun, 2008 at 07:43:50am
I know, it's my job! On 13th Jul, 2012 Ben H said:
25th Jun, 2008 at 08:32:37am
If Ben has got some 1/4 UNF helicoils you may aswel heli coil them. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
25th Jun, 2008 at 08:42:22am
Vegard you really can be a self righteous mother fucker sometimes.
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
25th Jun, 2008 at 10:42:41am
LMAO On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
25th Jun, 2008 at 10:33:13pm
I agree with V 100% on this, why start mixing threads when everything else will be AF |
25th Jun, 2008 at 10:42:54pm
Thank you Tom, I appreciate it, really!
On 25th Jun, 2008 Tom Fenton said:
Vegard you really can be a self righteous mother fucker sometimes. On 25th Jun, 2008 Vegard said: Tapping 8mm is fucking sacrilidge. If you are to tap it a bigger diameter be so smart to use 5/16UNF. I hat those mm/imperial mismatchers wankers! On 13th Jul, 2012 Ben H said:
25th Jun, 2008 at 11:30:44pm
i agree with both tom and vegard "Turbo's make torque, and torque makes fun"
