| Home > Help Needed / General Tech Chat > seat/floor strengthening | |||||||
524 Posts Member #: 1380 Post Whore Swindon |
31st Jul, 2008 at 11:53:32pm
In a recent topic this was bought up - but i couldn't quite picture it in my head.
On 23rd Jun, 2008 johnK said:
Another option for seat mount is to go onto the sill and the centre tunnel - using the front cross member as well - have done this with the seat in the gold car and its rock solid JK On 23rd Jun, 2008 wil_h said:
Mine was bolted to the floor and moved around loads. I now have two square-section bars that run from sill to tunnel which the seat is mounted on. ...My car is currently having panels etc welded. While it's in his unit i want to have whats described above carried out too. is it possible someone has a picture or 2. Or even a illustration in paint so i can describe to him what i'm after/show him so he can fabricate it? On 2nd Mar, 2008 joeybaby83 said:
neil_g, with all due respect, your the worse salesman on TM since rob_h tried to sell his own ass |
1st Aug, 2008 at 03:31:01pm
Edited by Bat on 1st Aug, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
31st Aug, 2008 at 02:26:50pm
thanks for the reply bat - the mini is now out of welding but will need to go back in once i have bought a rollcage.
31st Aug, 2008 at 02:32:33pm
31st Aug, 2008 at 05:00:53pm
I bought a MK1 cross member, cost £40, just offered it up, and welded it in :)
Edited by Sprocket on 31st Aug, 2008. On 26th Oct, 2004 TurboDave16v said:
31st Aug, 2008 at 11:22:09pm
i welded some 1" box across mine
31st Aug, 2008 at 11:22:45pm
this one shows it clearer
31st Aug, 2008 at 11:26:24pm
Mounts in that metro look borderline dangerous to me, looks like they are made from house radiator wall brackets.....not up to the job IMO.
31st Aug, 2008 at 11:43:21pm
Need to make the angle at least the same thickness as the mounts. They look like sparco mounts, so 3mm mildsteel minimum. Have the rear support at the end of the mount, not near the middle. Edited by Jason G on 31st Aug, 2008. On 19th Jan, 2010 wil_h said:
1st Sep, 2008 at 02:35:53am
I made custom brackets for the seats. These were made from 6mm 50x100m aluminium angle. I dont need that many holes, but as I was unsure of a confortable position, it made it easy to find it. I will re make them with only a few holes for slight adjustment :)
1st Sep, 2008 at 08:10:15am
I find that the seat is WAY to high in the car if you fit the brackets on the cross member(s).
1st Sep, 2008 at 11:20:09am
The brackets bolts look abit small. I think I used M8's possibly M10's on mine. On 1st Sep, 2008 Sprocket said:
I made custom brackets for the seats. These were made from 6mm 50x100m aluminium angle. I dont need that many holes, but as I was unsure of a confortable position, it made it easy to find it. I will re make them with only a few holes for slight adjustment :) On 19th Jan, 2010 wil_h said:
1st Sep, 2008 at 11:47:13am
m8 to meet FIA-regulations. On 13th Jul, 2012 Ben H said:
1st Sep, 2008 at 12:40:38pm
M8 12.9s mate, if they are good enough to hold the seat to the brackets they are good enough to hold the brackets to the floor:) On 26th Oct, 2004 TurboDave16v said:
1st Sep, 2008 at 12:43:03pm
On 1st Sep, 2008 Vegard said:
I find that the seat is WAY to high in the car if you fit the brackets on the cross member(s). I just bolted mine to the floor, obviously with some Proper FIA brackets. With those brackets I made, the seat at iots lowest adjustment, sits down inbetween the cross members, and the front lip of the seat is almost touching the cross member, no pint going lower than that
Whats with all the un nescisary negative comments today
1st Sep, 2008 at 02:25:32pm
Whats with all the un nescisary negative comments today ![]() They're not negative, they're helpful. If you want to sit like an old granny go ahead
1st Sep, 2008 at 02:29:05pm
Depends how tall you are I guess as to where the seat needs to be.
1st Sep, 2008 at 03:01:03pm
I prefer to have the seat high, but if you do track days etc you don't want your crash helmet hitting the roof especially if something happens. On 19th Jan, 2010 wil_h said:
1st Sep, 2008 at 04:07:57pm
nescisary??? Helpful/ negative Perspective
And dam fine English
well ok Necessary
My granny wouldnt reach the pedals
2nd Sep, 2008 at 05:54:24pm
i can rember when i was is neils car (wolfie) his seat position was awsome just dont know where he had his seat bolted onto lol. some pics would be awsome if somone has some :) Drives
