| Home > Help Needed / General Tech Chat > 1275 SPI Turbo | |||||||
2 Posts Member #: 3790 Junior Member |
9th Sep, 2008 at 03:49:20am
I am lookin to do a custom turbo setup on my 1275 Single port injection motor and wondered what all i would have to upgrade for the fuel system and how i would go about that being its a fuel injected motor, would i need a new injector? Fuel pump? how would i program the fuel curve if needed? thanks for the help |
9th Sep, 2008 at 03:53:37am
Easiest way is to throw away all the SPI gubbins and use a good old carburettor.
9th Sep, 2008 at 04:40:51am
Well... Running low boost, say 5 psi would i even need to adjust the fuel curve any? or allow for more fuel? |
9th Sep, 2008 at 04:54:12am
Yes. 5psi boost pressure is approx 30% more air than NA.
9th Sep, 2008 at 09:26:43am
There is a whole section on the forum entitked "A-Series EFI / Injection ".
9th Sep, 2008 at 12:50:47pm
you might find getting through emissions at MOT time difficult with an spi donor vehicle "Turbo's make torque, and torque makes fun"
9th Sep, 2008 at 06:22:40pm
9th Sep, 2008 at 08:15:28pm
if you change the engine on the log book to the engine from a metro turbo/era then you will come under the emmissions test for that engine and not the SPI engine.
9th Sep, 2008 at 08:43:38pm
On 9th Sep, 2008 James_H said:
if you change the engine on the log book to the engine from a metro turbo/era then you will come under the emmissions test for that engine and not the SPI engine. thats what ive got to try and figure out how to do... dont you just fill in your log book and send it off... i think its the age of the engine not the original vehicle, but other than that i have not looked into it as my mini's emissions is high as standard so my tester doesnt need to know
Yes i moved to the darkside |
9th Sep, 2008 at 09:04:54pm
yeah you should be able to but i am using the spi engine just swapping to carb etc. there are no codes for the engines are there just casting numbers? or are there?
9th Sep, 2008 at 10:39:01pm
9th Sep, 2008 at 10:41:49pm
yeah but how do they know the age of the engine? is there an engine code for the SPI and a different one for the Turbo unit?
9th Sep, 2008 at 10:46:31pm
9th Sep, 2008 at 10:57:05pm
do you know the eninge code for the turbo engine?
9th Sep, 2008 at 11:01:11pm
9th Sep, 2008 at 11:08:13pm
spot on |
9th Sep, 2008 at 11:19:34pm
one last thing. is the engine code on the engine anywhere? |
9th Sep, 2008 at 11:37:50pm
10th Sep, 2008 at 08:32:30am
ahhhh yeasssssssss that little plate, i remember now. Cheers Gav!! |
