| Home > Help Needed / General Tech Chat > Ford coil pack.. can this be used.. | |||||||
25th Sep, 2008 at 11:45:58pm
i was down at challow earlyer 2day and found a forg coilpack unbolted so i though to my self ill have that!
Edited by Paul R on 25th Sep, 2008. Drives
26th Sep, 2008 at 08:03:33am
I have never had a ford one from a scrapyard that doesn't work with edis. A coil is a coil, Ford are good at making things the same. http://www.twin-turbo.co.uk
26th Sep, 2008 at 08:26:16am
26th Sep, 2008 at 10:22:20am
I would use the right coil - or you will burn out your edis...
AlexF |
26th Sep, 2008 at 11:53:33am
okay thank you, ill go back 2day and get the other one i hid :) Drives
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
4th Jul, 2011 at 10:47:05pm
Have searched about and this post almost got me an answer...
On 26th Sep, 2008 Bat said:
Hi, I think most people use the same one as there's a set of leads off the shelf that fits the Mini quite well. Cheers, Gavin :) Any ideas what the leads in question are? And this "fit a Mini"; does it assume the coil pack is mounted on the flywheel housing? Or bulkhead? Many thanks in advance from a mech eng trying to understand the witchcraft of MJ
Dave PS last one (sorry!) where can I pick up a lead to connect the MJ to my laptop? this thread (http://www.turbominis.co.uk/forums/index.php?p=vt&tid=394855) concerned me in that some people seem to have tried several before finding one that suits. Thanks again. Edit; Poor grammar
Edited by Pottsy on 4th Jul, 2011. |
