| Home > General Chat > Spraying in Cold Weather | |||||||
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
17th Nov, 2009 at 04:05:59pm
I want to finish spraying my mini when i get back from uni.
458 Posts Member #: 1840 Senior Member Kings Lynn, Norfolk |
17th Nov, 2009 at 05:13:37pm
Are you using cellulose or two pack? |
17th Nov, 2009 at 05:18:16pm
You are going to struggle either way really, it is moisture that is your enemy with celly as it will "bloom", and if using 2k even with winter hardener it will not go off with no heat at all.
17th Nov, 2009 at 05:35:06pm
My car was sprayed in the winter. We used. A big gazebo in our farm workshop with a space heater to warm it up. We also had a fan on one end to draw out the fumes and paint in the air. We used 2 pack and had no troubles! |
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
17th Nov, 2009 at 06:17:19pm
I did mine last december with 2k using winter hardener it was ok.
17th Nov, 2009 at 07:05:09pm
be careful if using a gas/diesel space heater as if you havent got a decent roof (mines single skin) moisture from combustion will condense and drip :( "Turbo's make torque, and torque makes fun"
17th Nov, 2009 at 07:56:33pm
Thanks guys. (2 pack paint by the way.)
17th Nov, 2009 at 08:51:36pm
Pretty much all alike tbh. Your compressor should have a drain screw on the bottom aswell so make sure you drain it before you start and you'll get the majority out. |
17th Nov, 2009 at 10:56:17pm
Any air trap will be better than nothing, have a look on ebay and machine mart etc and see what you can get hold of for reasonable money.
17th Nov, 2009 at 11:32:29pm
I did mattys car on my drive last january
18th Nov, 2009 at 09:09:24am
Its not recommended, but I sprayed a car in the open(with cellulose) in November, with the spray gun in one hand a fan heater in the other and got an acceptable finish - but I was a bit desperate !. |
19th Nov, 2009 at 12:05:02am
I am spraying mine right now. You need to line whereever you are doing it in plastic and close all the edges to give yourself a bubble to work in. A small heater is a must but the plastic bubble will retain the heat extremley well. Own the day
15th Jan, 2010 at 08:21:28pm
Just a quick couple of questions...
15th Jan, 2010 at 08:34:28pm
dirty bugger!
On 17th Nov, 2009 Nic said:
I did mattys car on my drive last january I was surprisingly impressed with how it came out On 28th Aug, 2011 Kean said:
![]() 61 Posts Member #: 7857 Advanced Member NAILSEA, near bristol |
15th Jan, 2010 at 08:38:07pm
On 17th Nov, 2009 dan187 said:
I want to finish spraying my mini when i get back from uni. http://www.turbominis.co.uk/forums/index.php?p=vt&tid=326421 but it's going to be cold, damp and i'm working in a barn. I'm worried the finish will suffer from the weather... Does anyone have any suggestions? I may be able to move it to a smaller barn and try and heat the room. Would this be much of an improvement? I'm not sure how even the heat would spread in the room. How long would I need to keep the paint warm for? Or, Is there anyone local who has a nice setup i can come and use? Also I could do with a decent moisture trap, my compressor is spitting out a bit of water. What ones can people recommend? Cheers ive done allot of spraying all year round (qualified sprayer) in garages and alike, can i suggest you hook up atleast four 500w flood lamps on the four corners of the mini, not only will the radiate buckets of heat, but help give you light reflect to spray against. always worked a treat for me (it will caine electric tho) are you doing 2pack? id also suggest winter activators. and longet times between coats
15th Jan, 2010 at 08:39:55pm
Edited by Barney Rubble on 15th Jan, 2010. |
). Do I need to put more hardener in due to the cold weather?
