| Home > Help Needed / General Tech Chat > Washed it, now it lacks power | |||||||
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
3rd Apr, 2010 at 11:06:32am
Gave the mini a spring clean yesterday.
Edited by dan187 on 3rd Apr, 2010. |
3rd Apr, 2010 at 11:48:25am
Have the valves been re cut? On 26th Oct, 2004 TurboDave16v said:
3rd Apr, 2010 at 11:58:10am
check the coil connections aren't damp. If you have hosed it through the grill they may be damp and your ht could be shorting out. |
3rd Apr, 2010 at 12:00:31pm
As above, check all the ignition electrics for water and damp ingress. Also check inside the dizzy cap etc.
3rd Apr, 2010 at 12:03:32pm
Water on elecytics as both above but the change in compression from 75 to 105 on No3 implies rings are damaged, did you do the test with the engine hot ???
3rd Apr, 2010 at 12:29:57pm
On 3rd Apr, 2010 Rod S said:
Water on elecytics as both above but the change in compression from 75 to 105 on No3 implies rings are damaged, I beg to differ I reckon its valve seal. The additional oil will also help seal the valves. With such a varience in compression pressures I put that down to valve seal, which is why I asked the qiestion I did
51 Posts Member #: 8026 Advanced Member Hereford |
3rd Apr, 2010 at 12:36:19pm
Water on elecytics as both above but the change in compression from 75 to 105 on No3 implies rings are damaged, I beg to differ I reckon its valve seal. The additional oil will also help seal the valves. With such a varience in compression pressures I put that down to valve seal, which is why I asked the qiestion I did ![]() I agree with sprocket If your wife wants to learn to drive, don't stand in her way. |
3rd Apr, 2010 at 01:00:41pm
Fair point but oil normally seals the rings first - unless loads has been put in.
3rd Apr, 2010 at 01:11:36pm
if it were a valve the compression would not have come up
3rd Apr, 2010 at 02:45:52pm
Wow, thanks for all the replies.
3rd Apr, 2010 at 06:37:58pm
Head gasket? On 11th Feb, 2015 robert said:
3rd Apr, 2010 at 07:49:13pm
high cr and pump fuel = hard to start did on my mates 1380 anyways. possibly head gasket? Drives
3rd Apr, 2010 at 07:50:22pm
i can always pop up to you and have a gander if you like for a second oppinion as im close by :) Drives
4th Apr, 2010 at 11:10:53am
it could be the head gasket, this needs looking at first!
Edited by BENROSS on 4th Apr, 2010.
869 Posts Member #: 2443 Post Whore Cheshire |
4th Apr, 2010 at 11:54:53am
Agreed, white smoke would indicate water so either theres a lot o condensation or the HG is on its way out |
4th Apr, 2010 at 07:02:06pm
right, cleaned the dizzy cap and sprayed wd40 on all the bits and leads. Runs much better now (as it was before I washed it) cheers guys.
4th Apr, 2010 at 07:16:57pm
which sunday do you mean i only live in old town your only 10mins from me with my driving lol :) so if you had a spair half an hour i dont mind poping over Drives
4th Apr, 2010 at 08:42:19pm
On 4th Apr, 2010 dan187 said:
Would the head gasket blow through to the oil reservoir? I do seem to use a fair bit of oil and not a lot appears to leak out onto the garage floor. Not from No 3 where your compression is significantly lower. But the readings are ALL very low for a supposed 12:1 CR Adding oil useage to the other symptoms, my money is still on the rings, worn on all cylinders and damaged on No3. Schrödinger's cat - so which one am I ??? |
5th Apr, 2010 at 07:12:47pm
On 4th Apr, 2010 Paul R said:
which sunday do you mean i only live in old town your only 10mins from me with my driving lol :) so if you had a spair half an hour i dont mind poping over going back next sunday. Thanks, pop round in the week if you fancy it. let me know and i'll send you me address. On 4th Apr, 2010 Rod S said:
Not from No 3 where your compression is significantly lower. But the readings are ALL very low for a supposed 12:1 CR Adding oil useage to the other symptoms, my money is still on the rings, worn on all cylinders and damaged on No3. ok, checked with me dad. it's just under 11:1 not 12 (oops) Took the car for run around today, drives as well as it ever has. Did another compression test as soon as i got back... 125, 125, 90, 130 so still low in 3. There's not a lot i can do about it at the moment, will there be any damaged caused by running it? It's going on the rollers on Saturday so i can compare it to when i last had it on them. |
5th Apr, 2010 at 07:50:51pm
5th Apr, 2010 at 08:54:26pm
Tight tappet on No 3 ?. |
5th Apr, 2010 at 09:35:02pm
On 5th Apr, 2010 Sprocket said:
Still say thats a valve ![]() If it weren't for the fact they are ALL low and No 3 comes up with a SMALL amount of oil when hot, and there is overall excessive oil consumption....I would agree. But a small amount of oil on a compression test improving the reading says rings...... But as the compression readings are all low, and the oil useage, it could be a combination of things. I think we need to both be there when it comes apart before we agree
Edited by Rod S on 6th Apr, 2010. Schrödinger's cat - so which one am I ??? |
