Home > General Chat > t3 on a 998???
masterchief
Member #: 7308
Devon
well basically as title will it work? i have a few bits kicing about such as a 12g295, plenham and a complete t3 but would it be worth putting it on such a small engine?
any input welcome
It will work, but an educated guess tells me that it may as well be N/A until you hit over 5000rpm.
I guess you could always keep the compression high and the boost low to give it a bit of a power hike at high rpm's?
Carl S
Member #: 1761
Stalker
Unless your hillclimbing or sprinting it, don't bother with a T3.
masterchief
Member #: 7308
Devon
see thats what im thinking, anyone know what revs it may kick in at for sure then?
I believe the best qualified people to comment with be wil & ben. I'm not certain but I think they used a T3 on their hillclimber.
Ben H
Member #: 184
Melton Mowbray, Pie Country
We did use a T3 on the hillclimber and I would not advise it on a road car. The power came in with such a bang and at such high revs that it was not great.
I am sure Wil has a print of the power graph somwhere, but not much below 4k and then all done by 6k. This could be improved, but we decided that a different turbo was a better place to start development.
http://www.twin-turbo.co.uk
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Here is a RR comparison of the T3, T2 and GT1752 on the twins hillclimber
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=164482
On 30th Apr, 2010 Rod S said:
Gary's description is best
It actually looks on that graph that the T3 and GT17 are comparable in boost threshold, but the T3 was a lot worse to drive.
Also the T2 on that graph was improved massively by modofing the exhaust elbow and manifold.
I would not recommend fitting a T3 or a GT17 for roaduse on a 998 other than for a laugh.
sturgeo
Member #: 1778
Northants
Hmm we were considering putting the gt17 on the efi 998 to replace the t2.
I guess we won't know what it's like on a road going car until we try...
dan187
Member #: 6724
Wootton Bassett
Wil..
and it says in the linked thread you changed the adapter plate.
Could you explain what the mods were that gave you better output?
1275 EFi Turbo
I had blended the adapter plate to the shape of the Metro manifold, but this leaves it very narrow on the two outside bores.
I basically took a grinder to the seperators in the manifold to open it all out.
That's not right. We are going to fit a GT1752 on the 998 at the next build. Better head and piston buttons so that we can run higher revs get more power, but keep the torque at 105 curleys so that we don't destroy the helical box or verto clutch.
It will make aninteresting comparison.
i think i ran around 115 to 125 lb/ft for ages with no probs paul.
True, I would need to uprate the clutch though.
I think that I may have to find a hybrid or try a GT1548. Looking at the RR graphs for the TT2, it comes on full boost at 4500rpm, whereas we are currently seeing full boost by 4000rpm with the T2. Even if I push the rev limit to 7000rpm, I will only get another 500 useable rpm on full boost.
I could do with the GT1752 compressor on a T2 turbine.
I have a feeling that if you stuck the T2 turbine on the 17 comp then you'd run into surge.
