Home > 998cc > 998 turbo
softlad1988
Member #: 8462
Would u get good results if if fitted hepolite dished pistons and a 12g202 head, t2 turbo and a standard cam?
Ben H
Member #: 184
Melton Mowbray, Pie Country
Depends what you mean by good, but over 80 bananas would not be unreasonable. Not sure about the pistons though.
http://www.twin-turbo.co.uk
softlad1988
Member #: 8462
what pistons would be best for around a 100bhp?
dan187
Member #: 6724
Wootton Bassett
standard ones, see my build below.
I'm getting 80bhp with a standard head. Got a 12g295 head and metro cam to fit which should push it up to the 100bhp mark
1275 EFi Turbo
softlad1988
Member #: 8462
you are getting 80bhp with a standard 998 head? how have u lowered the compression?
dan187
Member #: 6724
Wootton Bassett
yeah opened it out to give a few more cc's. Don't know what compression tho. Couldn't measure at the time.
I'll measure it when i take it off (hopefully over Christmas)
1275 EFi Turbo
A 6cc piston dish with a standard head will give below 9:1 CR, fine for lots of boost.
As above, you don't need fancy pistons for moderate power.
softlad1988
Member #: 8462
what cc would i need to open a standard head out to to get 9:1??
Depends what cc you have in your pistons
softlad1988
Member #: 8462
the standard flat top pistons! will these be ok to use? they have only done around 40,000 miles
Spank
Member #: 909
standard flat tops give you 10:1 compression using a stock 998 head if I recall. You'll need bigger head chamber to get compression down.
Correct, with flat tops you need around 28cc in the chambers. Otherwise it's finr to use the flat tops
Bodge Job
Member #: 953
London
what cr do you get when using a 12g295 and standard pistons ?
Around a little over 9:1
