| Home > Help Needed / General Tech Chat > MG Metro Cam Timing-In | |||||||
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
1st Mar, 2011 at 02:12:00pm
When fitting the N/A MG Metro Cam for a turbo application what timing have people used?
1st Mar, 2011 at 02:20:38pm
108 seems to work for us on the van. If something is worth doing, it's worth doing half of. |
1st Mar, 2011 at 02:41:25pm
I've installed three or four MG Metro cams and have always had to advance them at least 5 degrees from the dot to dot to get 108. On 13th Jul, 2012 Ben H said:
1st Mar, 2011 at 02:59:14pm
Van has a 5 degree key in i believe V If something is worth doing, it's worth doing half of. |
1st Mar, 2011 at 03:13:33pm
Cheers chaps.
1st Mar, 2011 at 03:19:47pm
I think 108 is the best for a turbo engine. Chain stretch should only loose you 2-3 degrees On 11th Feb, 2015 robert said:
1st Mar, 2011 at 04:14:17pm
The dots are good enough for either a starting point, or standard engines for your granny. You always need to check and correct to get the best out of the engine.
1st Mar, 2011 at 04:16:07pm
Does the don have an offset key Tom? If something is worth doing, it's worth doing half of. |
1st Mar, 2011 at 04:17:47pm
I'll offset your bloody key if you keep asking daft questions boy!!!!!! :)
1st Mar, 2011 at 04:22:11pm
its obviously easy to wind up john Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
1st Mar, 2011 at 05:13:08pm
john may like that tom .....LMAO
1st Mar, 2011 at 05:54:52pm
mine was 111.5 dot to dot its gone in at 107.5 Yes i moved to the darkside |
1st Mar, 2011 at 06:53:34pm
On 1st Mar, 2011 Brett said:
mine was 111.5 dot to dot its gone in at 107.5 My experience as well. On 13th Jul, 2012 Ben H said:
87 Posts Member #: 10069 Advanced Member |
25th Jan, 2013 at 10:13:26pm
Erm guys confused.com
25th Jan, 2013 at 10:20:26pm
the advice is that you should check it and if required correct it with an off set key..
26th Jan, 2013 at 10:34:01am
As above, do a search on cam timing. It should answer your question |
27th Jan, 2013 at 08:45:45pm
Like a rabbit caught in the head lights........
27th Jan, 2013 at 08:55:52pm
I would measure, then fit the correct camshaft key, but I must admit, if choosing from dot to dot or a 5 degree key, I'd go with the key.
976 Posts Member #: 3228 Post Whore North of the Netherlands |
23rd Aug, 2018 at 08:32:59pm
Gents, after a bit of advice;
Dazed and Confused.... |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
26th Aug, 2018 at 10:07:49am
Mine is in at 107. Figured it Will delay a bit once chain streches. you can do anything if you set your mind to it...
26th Aug, 2018 at 11:06:33am
Thanks Rammie,
