Home > General Chat > Water Cooled Inlet
pot_dan
Member #: 326
bradford, west yorks
I know I am in real risk of opening a can of worms but I really want to know the truth as some people say it should be used as designed and some that don't use it. I personally have never used it but I have allways wanted to use it with a charge cooler. But I don't think I will ever be using a charge cooler.
Anyway has anyone tested inlet temps with it connected/disconected?
http://turbominis.co.uk/car/105/
jamie@thefatgarage
Member #: 9345
Sheffield
If you are talking about inlet manifolds with water piped through them it's not to cool it. It's to warm it up faster from start up allowing warm up enrichment to end earlier. It's an emissions thing.
jamie@thefatgarage
Member #: 9345
Sheffield
p.s.
on the charge cooler front it doesn't have enough surface area to be effective.
Pottsy
Member #: 843
Stoke-on-Trent. Duck.
I've often wondered about the water heated inlet manifold; what's the general consensus on having the inlet heated (i.e. piped up).
Obviously we all want a cool charge getting to the carb for greater air density (hence intercoolers) but does the heated inlet then affect the air/fuel mix in a positive or negative manner? Ignoring the whole start up issue of course.
Dave
it does help part throttle driveability in the winter, on my 998 it cured its carb icing aswell however it didnt on my 1275
i think can of worms is the best way to describe it, try fit it if there is no gain there is no harm n taking it off
jamie@thefatgarage
Member #: 9345
Sheffield
Hot coolant at 90+ deg C is never going to help power. I'd be disconnecting it if I had one. I don't think it makes much difference though for the same reasons it won't work as a charge cooler. Not much surface area..
Mixture isn't really positive/negative. It's right or wrong. If you alter anything from when it was last tuned then it needs checking and adjusting. This is why programmable fueling as well as ignition is the easy option.
tadge44
Member #: 2500
Buckinghamshire
Water heating of the inlet manifold is not so much an emissions thing as making the car more driveable, especially when either the weather or the engine is cold.It makes a rwal difference in that way.
If you are prepared to sacrifice that aspect, then a cooler charge is obviously better for power.
it makes a massive difference if its real cold
dan187
Member #: 6724
Wootton Bassett
They work by heating the manifold so that if cold fuel drops out of the air and onto the manifold it will evaporate and go back into suspension. This is how it helps cold starts. The effect on the incoming air temp is negligible because as said the small surface area and time in contact mean there is little heat transfer.
1275 EFi Turbo
Utking
Member #: 9342
Southern Norway.
hmm, so will this help a little on cooling our hot mini's? i was thinking, even if it has a small contact area, you would spread the water in a metal housing, wich will be cooled by an intercooler. what do you think?
dan187
Member #: 6724
Wootton Bassett
you mean cool the water with the inlet air?
doubt you'd notice for the same reasons
1275 EFi Turbo
pot_dan
Member #: 326
Well that's cleared that up then! I must have made that argument up in my head.
I understand about little surface area and the charge cooler idea not working also so glad I asked. *smiley*
And as I don't use my car in the winter i shall continue not using it.
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
Just take your intercooler off for the winter problem solved *laughing*
and just to preempt to inevitable abuse ill get for that comment I was only joking
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
