| Home > General Chat > exhaust clearance for samco hose | |||||||
8th Jun, 2011 at 04:02:22pm
how close to an exhaust manifold is too close do you think?
Yes i moved to the darkside |
8th Jun, 2011 at 04:35:14pm
I would think it depends what is in the hose. Water could go closer than air. Never had one closer than about 25mm though so apart from that pearl of wisdom, I have no idea!
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
8th Jun, 2011 at 04:47:24pm
i guess you mean in case it melts. my samco extreme (higher heat resistance) seems fine so far with about 2mm gap |
![]() 865 Posts Member #: 951 Post Whore Bromsgrove |
8th Jun, 2011 at 05:31:50pm
Heat wrap the Samco. 'Where does the engine go?' |
8th Jun, 2011 at 05:40:51pm
Mine is about 10mm and has been for years. It's a bit discoloured, but otherwise solid. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
8th Jun, 2011 at 05:56:26pm
is yours close to the manifold flange on the GT20 brett? think i've got about a 5mm gap on mine now after grindiong it away and its fine :) On 20th Oct, 2015 Tom Fenton said:
8th Jun, 2011 at 06:06:44pm
yes nick, obviously this turbo wasnt meant to run in this orientation, its about 8 mm from its own flanges, its on now anyway fettled and filed (yes it took ages lol)
8th Jun, 2011 at 06:15:42pm
I have had to heat wrap both the I/C pipe and the air inlet to the compressor with the way I have oriented the GT17.
8th Jun, 2011 at 10:46:34pm
i have an IC pipe touching the jubilee clip which is also wedged between the turbo flange. so i have NO GAP. i have some blackening of the IC pipe but no hole as of yet. and its been like that for about 4months, it did also set on fire too (because of oil on the turbo) and its still going strong |
9th Jun, 2011 at 12:10:59pm
Genuine samco or any other proper silicone hose is supprisingly heat resistant, if I have some under 10mm from a manifold I usually just make a wee double skinned stainless heat shield, usually works a bit nearer than wrap :)
9th Jun, 2011 at 12:20:20pm
yes genuine samco, note the 'adjustment' on the aubment plate no matter how much you fettle something gets missed lol Yes i moved to the darkside |
9th Jun, 2011 at 12:22:48pm
Looks alright to me Bertt! If something is worth doing, it's worth doing half of. |
9th Jun, 2011 at 06:40:28pm
thatll be fine, however, if you get some thin stainless/aluminuim (cat heat shield of a scrap car turbo 16v k-series 11.9@118.9 :)
9th Jun, 2011 at 07:11:08pm
yeah see what you mean, and i will do that Yes i moved to the darkside |
9th Jun, 2011 at 08:16:50pm
That will be fine mines been running that close for about 6 years with the same hose no bother :) |
9th Jun, 2011 at 09:06:08pm
mines like that but actually touching the turbo flange... and it seems fine |
) and fold it over and tuck a bit under that jubilee clip you will have a heat shield, just incase :)
