Home > Wanted > Distributor body to modify for cam phase sensor
dan187
Member #: 6724
Wootton Bassett
I'm after a body which is in suitable for making a cam phase sensor out of. Just needs to have a A+ drive and spin in its body. Not worried about having complete workings above that.
£.... Ideally free because it would be mostly broken
Edited by dan187 on 4th Nov, 2011.
1275 EFi Turbo
I'm prety sure I have an old shitter you can have. Will be Monday before Iget a chance to look though.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Pretty sure I have one too if will can't turn one up.
http://www.twin-turbo.co.uk
dan187
Member #: 6724
Wootton Bassett
would be great thanks chaps. let me know.
1275 EFi Turbo
eden7842
Member #: 8852
leicestershire
also got loads if you wana drive to lesta
almichie
Member #: 2065
I have an spi one here...
And I have a sensor for what you need too.....
Shaft seems nice and snug
Wouldn't an Spi dizzy be prefect for this?
dan187
Member #: 6724
Wootton Bassett
Oh really? Does it have a built in phase sensor? Anyone know what the type of sensor is? But if it's good for ms3 then yea please almichie.
1275 EFi Turbo
I thought the SPI one was just an empty body with a rotor arm on the end of the shaft for the HT only.
The SPI wasn't sequential injection so didn't need a phase sensor, just a crank sensor.
almichie
Member #: 2065
Correct the spi Is an empty dizzy. BUT I have a HALL sensor that could be used - you'd need to fabricate a cage to a fairly high standard to use it though - or just use something else.
dan187
Member #: 6724
Wootton Bassett
depends how much you want for it? was looking for one at the cost of postage.
1275 EFi Turbo
I should have a dizzy body throwing round. Will have a look tomorrow
dan187
Member #: 6724
Wootton Bassett
cheers
1275 EFi Turbo
Just found an unknown 45D dizzy, yours for the cost of postage. Shaft seems nice and snug, so should be fine for your purpose.
almichie
Member #: 2065
You can have mine for the same - not the sensor though. But if you want points for the trigger - go with Andy's!
dan187
Member #: 6724
Wootton Bassett
Thanks for the offers guys. apbellamy has sorted me out.
Dan
1275 EFi Turbo
jamestar
Member #: 9159
Devon
Has to be a sig for someone! *hehe!*
Edited by jamestar on 7th Nov, 2011.
almichie
Member #: 2065
*happy*
