Home > Ebay items For Sale > no need for plenum?
mayoturbo
Member #: 1395
chepstow
http://www.ebay.co.uk/itm/mini-metro-hif44...6ccdfe86&_uhb=1
TurboMike1992
Member #: 9928
Hartley, Kent
That can't be right surely? No restrictor ring or anything?
Low boosting for now.
as long as the fuel pressure regulator and float bowl are correctly pressurised above manifold pressure there should not be not problem, i would assume the needle would need to be a fair amount different to standard
dan187
Member #: 6724
Wootton Bassett
well apparently he ran a relay with it.
1275 EFi Turbo
Yes, but the fuel pressure regulator has no bearing on the pressure of the float bowl.
To make this work you would need a seperate feed to the float bowl to increase its pressure with boost; either down the hole from the plenum where it usually comes from, or you could use the breather pipe.
The feed will either need to be taken from somewhere close to the compressor where it is at a higher pressure than at the manifold (assuming you have an IC that is dropping the pressure), or you could use a Pitot tube.
Just banging this on will not work, which is, I suspect, the real reason for the sale.
yes i understand that but the float bowl needs to be atleast the same pressure as the boost, you can run perfectly fine with no restrictor but the needle needs to be sooo thin by the time your pushing 10psi boost you cant fuel any more. That 1-2 psi drop from plenum to carb that restrictor creates is not worth the hassle removing it would create
eg my needle for my non restrictor plenum ( i could only fuel for 10psi @12afr) causes a complete rich cut out at 20psi boost on a normal restricted plenum it was so rich by 20psi boost it wouldnt pull beyond it and il talking 3-3.5krpm
there are other ways to replicate the restrictor that have been discussed on here i feel in some detail eg the pilot tube and you can use the pressure drop across the whole intake side (intercooler and piping creates enough drop in pressure to upset my boost controller)
Edited by Brett on 16th Oct, 2012.
Yes you are correct about the restrictor. If you retain the plenum your float bowl will at least see boost pressure. but the thing linked to had no means of even pressurising the float bowl and as such will not run any boost.
yes i agree, now i have looked closer at it, it doesnt have the holes to pressurise underneath the main piston either, the holes on the dodgy flange look to be in the wrong place
