Home > For Sale > MPi Block, Pistons & Rods, EDIS Module, Boost Solenoid
dan187
Member #: 6724
Wootton Bassett
I will get pics up when i get home. I will work out postage costs if required.
Has rust damage in 1 bore. May get away with 1293 overbore. If not it is linered so will need 1 new liner. Otherwise good condition.
£80
Used set of +20 pistons and pins. Metro Turbo Spec: 22357. Slightly worn.
£30
Set of used standard pistons on rods. Came out of an MPi. Good condition.
£35
Crankshaft removed from MPi. Good condition.
£60
Edited by dan187 on 30th Jan, 2013.
1275 EFi Turbo
kappa
Member #: 9854
Hounslow, Middlesex
What cc are the +20 pistons, are they suitable for a turbo conversion? If so I will take these
Edited by kappa on 29th Jan, 2013.
kappa
Member #: 9854
Hounslow, Middlesex
Would the crank be stronger than a standard metro turbo crank?
tadge44
Member #: 2500
Buckinghamshire
You have PM
dan187
Member #: 6724
Wootton Bassett
I think they were around 10cc. Have a check on google so you're sure. Yes they are suitable, I think they were the standard metro turbo overbore piston.
I expect it will be no different
1275 EFi Turbo
dan187
Member #: 6724
Wootton Bassett
based on first come first served:
sim_ou_nao has the crank and turbo pistons pending payment
I'll get some pics up in a bit to make sure he's happy with it.
Dan
Edited by dan187 on 29th Jan, 2013.
1275 EFi Turbo
kappa
Member #: 9854
Hounslow, Middlesex
Was I not first to come on the pistons and crank? IF so I will take them now?
dan187
Member #: 6724
Wootton Bassett
sorry kappa based on the time the pms came through sim_ou_nao was first by an hour. you have second dibs if he changes his mind. sorry for the confusion.
1275 EFi Turbo
kappa
Member #: 9854
Hounslow, Middlesex
oh man, well give me a shout if it fall through, as I am really interested
dan187
Member #: 6724
Wootton Bassett
pictures: and some more parts for sale...
MPi Pistons
block
turbo pistons
MPi Crank
EDIS Module £10
Boost solenoid from unknown vehicle (i've forgotten what it was from, it was from a scrap yard)
£5
1275 EFi Turbo
dan187
Member #: 6724
Wootton Bassett
Crank and turbo pistons sold
1275 EFi Turbo
